[Z06] Passenger side window won't go down...
Old Feb 12, 2006 | 04:55 PM
Sixxcat1's Avatar
Sixxcat1
Default Passenger side window won't go down...
Is there a window lock feature I'm missing? Never really roll down my windows, but I was cleaning the interior today and noticed the passenger window wouldn't go down. I can hear a switch, but that's it. Any help? Thanks.
Old Feb 12, 2006 | 06:38 PM
wstory1's Avatar
wstory1
Where are you? Is it possible it's frozen shut? Mine has don that.
Old Feb 12, 2006 | 07:02 PM
Sixxcat1's Avatar
Sixxcat1
Las Vegas. No freeze here. Thanks though.
Old Feb 12, 2006 | 07:12 PM
gsjack's Avatar
gsjack
Common prob on the Z06 is a sticking or bad window switch. Try and tap on the passenger side switch while lowering. Seems from lack of use, they either stick or can go bad.
Let us know...Good Luck
Jack
Old Feb 12, 2006 | 07:19 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
While it could be mechanical, or a switch problem, there is also a computer in the door that controls functions on the passenger side of the car including the mirror, door locks, and window. I got mine wet and the contacts corroded. Had to replace the computer. Cost about $150 for the part and I did it myself.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 12, 2006 | 07:38 PM
Sixxcat1's Avatar
Sixxcat1
Thanks. I'm going out to fool with it now.
Old Feb 12, 2006 | 07:51 PM
zo6vetteman2003's Avatar
zo6vetteman2003
Sounds like the window regulator. They cost about $280.00 to fix at the dealer. I had two go at once on my Silverado and one go on my wife's YukonXL.
Old Feb 12, 2006 | 07:54 PM
Sixxcat1's Avatar
Sixxcat1
I'm thinking that's the problem.
Old Feb 12, 2006 | 07:59 PM
zo6vetteman2003
Most likely. I've had three fail like I said, all newer GM vehicles too. My 03 ZO6 is probably next.
Old Feb 12, 2006 | 08:00 PM
zo6vetteman2003
http://www.complaints.com/directory/...mber/13/42.htm
Old Feb 12, 2006 | 08:07 PM
Sixxcat1's Avatar
Sixxcat1
Thanks everybody.
Old Feb 12, 2006 | 08:11 PM
zo6vetteman2003
I think GM knows that they are a problem, but rather go on fixing them for cash. Makes me mad, because it has cost me plenty. I heard that they may be able to fix it under warranty, but I'm not too sure.
Old Feb 12, 2006 | 09:56 PM
Sixxcat1's Avatar
Sixxcat1
Just pulled it in the garage for the night and the window worked fine.
Old Feb 12, 2006 | 11:37 PM
gsjack's Avatar
gsjack
Seems if you use it frequenty, helps the contacts, not always.
Sometimes it just pukes and you have to replace the regulator.
Jack
Old Feb 13, 2006 | 09:13 AM
zo6vetteman2003
Beware, the problem starts out intermitent.
Old Feb 13, 2006 | 12:00 PM
procharged_z06's Avatar
procharged_z06
im having the same problem with my 01 z . im thinking its the regulator $280.00 .
Old Feb 13, 2006 | 01:36 PM
95jersey's Avatar
95jersey
very common problem with C5's. It will only get worse.
Old Feb 13, 2006 | 06:33 PM
90pololt4's Avatar
90pololt4
My 02 Silverado trucks went out last week on the drivers side. Good luck from GM!
Old Feb 13, 2006 | 08:07 PM
zo6vetteman2003
Tough going through the Dunkin Donuts drive through, have to open the door to order.
To Passenger side window won't go down...
