Changing headlights bulbs C5
Old Feb 12, 2006 | 07:56 PM
J's Toy's Avatar
J's Toy
Default Changing headlights bulbs C5 (Done!Thanks Everyone)
Ok i've done a search for changing the headlight bulbs in my 2000 C5 with no luck. Could someone please point me in the right direction. All i need to do is change the low beam bulbs.
FYI-What the forum needs is a DIY section. What do ya think?
Old Feb 12, 2006 | 08:01 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Someone had step by step instructions here several months ago. They sure helped me when I switched to SilverStars.
Old Feb 12, 2006 | 08:02 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Try a search for 9005. Wait... I will... heres a link with a few that may help.
Old Feb 12, 2006 | 08:58 PM
J's Toy's Avatar
J's Toy
ttt
Old Feb 12, 2006 | 09:01 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
This link should help. Just click on the word "link".
Old Feb 12, 2006 | 10:03 PM
rws.1's Avatar
rws.1
link does not work
Old Feb 12, 2006 | 10:11 PM
dadvan99's Avatar
dadvan99
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
This link should help you out.
http://forums.corvetteforum.com/show...s&forum_id=103
Old Feb 12, 2006 | 10:18 PM
Mpwr's Avatar
Mpwr
To get the bulb out you must keep the light in the off position and closed other wise you will not be able to get ur hand in there. But fist remove the black cover by turning the light on in the upright position and remove the three phillips screws and pull forward. It comes right out. Once you do that close the light and try and get your hand behind the light its really tight so if you have large hands try and get someone with smaller ones. The low beam its the out side bulb and the high is the inside so when ur hands in there feel for the first plug once you do that go a little futher to the second and give a slight twist in both directions im not sure which way is correct. Only will loosen if twisted correctly and pull out. Its very simple the hardest part is fitting your hand in there. I hope this helps.
Old Feb 12, 2006 | 10:22 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
St. Jude Donor '05 thru '19
The procedure is in the owners manual.
Old Feb 13, 2006 | 04:48 AM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
most importantly...be careful to seat them correctly and not bend the tabs that hold them in or you will be pissed
Old Feb 13, 2006 | 10:39 AM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
To Changing headlights bulbs C5
