Yesterday my passenger side window would not operate (go down). No unusual noises or anything of that nature. Today it's working perfectly. Go figure? Has this happened to any of you before and if so, what could be the cause?
Had this and a few more gremlins doing the cha cha in my electrical system after doing the headlight motor upgrade. it seems that the ground did not fully reconnect when I reconnected the gang plug. These cars, and I found this out the hard way, are very susceptable to crazy and seemingly unrelated problems due to bad grounds. If you have unplugged anything recently, check your plugs and maybe clean and apply a little dielectric grease. I understand it can also be caused by a bad battery. good luck....Bob
I unplugged the MAF sensor when I installed my Blackwing a couple weeks ago. And my battery is less then 6mos old. I guess I should count my blessings as this is the first thing that has gone wrong since I bought my 2000 over a year ago.
Thanks,
Chris
just whack the door panel a couple of times or slam the door. weird but it works. mine did it once along time ago but i did this "repair" and its working fine to this day. been over a year.
..IS one of the C5 TECH TIPS listed ...go to top bar & click on OTHER, then Tech Tips, then C5, then the C5 Related Tech Tips screen will appear...scroll down & click on Possible Remedy for a Stuck Window...it works...This usually happens on pass. side windows that are not used much...I didn't lower mine for the 1st 3 years!...then it was stuck! I freed it up using this Tech Tip.....
