HUD Install
Old Feb 15, 2006 | 07:06 AM
Purple Corvette Jim's Avatar
Purple Corvette Jim
Default HUD Install
I have a 98 Coupe A4, I want to get the HUD option installed. I live in the Northern Burbs of Detroit. How much should this purchase and install costs. Does the dealers do this type of install ? Any inforamtion would be appreciated.
Old Feb 15, 2006 | 07:14 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Check this out....
http://joshker99.home.comcast.net/hudinstall2.htm
This excellent info has been used by many of us to install HUD's in our non-HUD equipped cars. Good luck
Old Feb 15, 2006 | 07:15 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Try this link.HUD Install
I added HUD to my Y2k coupe. Not a bad job. Fred Beans has the HUD for just over $300. You will have to find a newer cluster for 98.
Good Luck
Old Feb 15, 2006 | 07:41 AM
Purple Corvette Jim
Default projector is 1100 bucks ??
Good Luck
Projector is 1100 bucks ?? Wow, now that is pricey !! What would the labor for this work come to. I would also guess that most people don't have this added, since the parts alone cost 1300 bucks. Thanks for the info on this.
Old Feb 15, 2006 | 08:02 AM
JeepTJ's Avatar
JeepTJ
Call Gene at Fred Beans Gene . Those prices on Josh's web page ARE VERY OLD. You can get the projector and control for $300.
Old Feb 15, 2006 | 08:31 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
shouldn't cost more than $200 for the install, it only takes about an hour to remove the cluster and dash cover, not a difficult;
try posting in your regional section, to see if someone may help you
Old Feb 15, 2006 | 09:37 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Jim,
I just did this exact install last weekend! I live about 20 minutes from you. My zip is 48371. I used all of the website mentioned above, but noticed that all of them lack some information. I did my own write up but it is saved as a word document. If you have an email i can send it to you!
Also, I really enjoy working on these cars so if you need any help im here for ya.
I did my ENTIRE install and all of my parts only cost me 450 dollars including the projector, cluster, bezel, wire harness, and switch although i did get a pretty good deal.
The only thing thats different is I have a manual trans so removing the radio/hvac surround may be slightly different with the A4. Other than that, the hard part is putting the dash back in- two people are needed to make it easier.
Rian
Old Feb 15, 2006 | 06:31 PM
BiggieBoy's Avatar
BiggieBoy
Originally Posted by Stealthy4
Jim,
Rian
Now, there's an offer hard to beat....
To HUD Install
