Miss-shift aftermath
Old Feb 15, 2006 | 04:50 PM
Raped-Ape's Avatar
Raped-Ape
Default Miss-shift aftermath
I was doing some spirited driving about 2 weeks ago , as i was going around a sweeping right hand turn i went to shift from 3rd to 4th , but hit 2nd instead. the car acted fine. nothing wrong . Then yesterday i went wot for the first time since it happened and the car sputtered real bad in the 4500-5000 range. I pulled the pushrods to see what was up. ill let the pics speak for themselves:
Old Feb 15, 2006 | 04:54 PM
Billy182's Avatar
Billy182
Ouch!!! I guess that's what happens when stuff moves too fast! Luckily your bottom end stayed together!
Good luck with it, keep us posted!
Old Feb 15, 2006 | 05:02 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Damn
Old Feb 15, 2006 | 05:08 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Ouch!!
Old Feb 15, 2006 | 05:10 PM
Hammie's Avatar
Hammie
Must be nice to know how to just pull push-rods conveniently. I would've sat there stupified and harrassed you guys as to what my next mode of action should be. Sorry to hear.
Old Feb 15, 2006 | 05:12 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Wow--very lucky no bottom end damage
Old Feb 15, 2006 | 05:15 PM
Raped-Ape's Avatar
Raped-Ape
new set of hardened comps on the way
Old Feb 15, 2006 | 05:22 PM
Sorry about the damage. Lucky it wasn't more.
Old Feb 15, 2006 | 05:30 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Feb 15, 2006 | 05:36 PM
tramminc's Avatar
tramminc
sorry to hear about your troubles. good luck
Old Feb 15, 2006 | 05:52 PM
diyguy's Avatar
diyguy
Interesting, Do you know how high the over-rev went?
Old Feb 15, 2006 | 05:56 PM
mowton's Avatar
mowton
Relative to Hardened pushrods, someone posted an interesting scenario.....
would you rather replace a set of pushrods or replace damaged cam, lifter, rocker etc.?
interesting options!!!!!!!!!
Old Feb 15, 2006 | 06:01 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Have you removed the electronic cut-off? Or how did it get to a high enough RPM to do that damage?
I had a 289 with a bent pushrod and I didn't find it out until the the misaligned rocker had chewed its way halfway through the rocker stud.
Old Feb 15, 2006 | 06:14 PM
Billy182's Avatar
Billy182
Read through his post again, you'll see that the engine was mechanically forced to over-rev (by accident), and no rev limiter in the world could have stopped that
The same thing happened to me with my rotary engined twin turbo RX7 during a roadrace a few years back. Luckily for me, the only thing that engine does is spin round and round (the tach went off the scale, which I'm assuming probably happened here too)
Old Feb 15, 2006 | 06:23 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Feb 15, 2006 | 06:24 PM
navy99vert's Avatar
navy99vert
Originally Posted by Stangkiller
Damn
Old Feb 15, 2006 | 06:31 PM
ebubman's Avatar
ebubman
ouch! my aching @ss! bub
To Miss-shift aftermath
Old Feb 15, 2006 | 06:45 PM
edensknight's Avatar
edensknight
Frack!!! Very lucky, indeed!
Old Feb 15, 2006 | 06:53 PM
Cscokd's Avatar
Cscokd
unbelieveable....damn...think I better go change mine just because...glad there's no major damage.
Old Feb 15, 2006 | 06:57 PM
mrC5er's Avatar
mrC5er
I'm no certified mechanic, but I think I'd stick with stock rods. If it happens again, just more bent ones hopefully. With hardened rods, it could get ugly.......dropped valve, damaged rockers, cam, etc.
Just my $.02
