PCM removal
Old Feb 15, 2006 | 07:39 PM
SLPRC5's Avatar
SLPRC5
Default PCM removal
How do you remove the PCM in a '97 C5..
Rsty
Old Feb 15, 2006 | 08:04 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've heard that one can remove a panel on the inner fender on the passenger side.
I doubt if you have to remove the whole fender like we did (for a different reason) - but here's a pic if that helps....
Old Feb 15, 2006 | 08:12 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
1. Raise the car
2. Remove the right front wheel
3. Remove the wheelhouse filler panel
4.Remove the fasteners holding the Throttle Actuator Control (TAC)
5. Disconnect the PCM electrical harness conn.
6. Loosen but do not remove the PCM rear retaining fastener. Use the rear retaining fastener as an anchor for the outer bracket.
7. Remove the front retaining fastener from the PCM
8. Reposition the PCM outer bracket
9. remove the PCM from the bracket and the car
Old Feb 16, 2006 | 01:40 AM
SLPRC5's Avatar
SLPRC5
WOW.... glad you cleared that up. Thanks for the cut away look so I knew what I'm looking for. Looks forward and simple to do.
Thanks,
Rsty
To PCM removal
