Replaced door lock relay in less than 1/2 hour
That is right, from start to finish it took me about 1/2 hour to take the door panel off, remove the door module, un-solder the relay, install the new relay, and put it all back together. I had been having problems with the passenger side door lock not working all the time. After reading up on it here, I ordered several new relays and gave it a try. Now it works like a champ. If anyone ever needs help, let me know.
Received 19,482 Likes
'20-'21-'22-'23-'24
Congrats. Nice to be able to do something to the car yourself.
Most of the information that you need can be found with this link:
http://forums.corvetteforum.com/show...ule&forum_id=1
I has nice pictures of the door control module, the relays, and a view of the relay itself. The only hard part will be un-soldering the relay. If you don't have a soldering iron or know of someone, let me know and maybe we can work something out. Good luck guys.....Dwayne
