Glove Box removal...
Old Feb 16, 2006 | 10:37 PM
CUlookin's Avatar
CUlookin
Default Glove Box removal...
There has got to be an easy way to remove this thing... I spent 45 minutes playing with it and couldn't get it out... I did get it to drop down farther with the tabs on the sides, but how do you get the hinge assembly out?!? Anyone know??
-Rob
Old Feb 16, 2006 | 10:45 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Open box pull plugs in bottom there are two 10mm bolts inside also there is a screw on passenger side of dash almost to door jamb.
Old Feb 16, 2006 | 10:48 PM
dlyle86's Avatar
dlyle86
5th Gear
And a couple of 7mm screws in the top.
Old Feb 17, 2006 | 10:10 AM
CUlookin's Avatar
CUlookin
thanks guy, I appreciate it!
To Glove Box removal...
