Is this happening when you are moving or parked. The sensors go to sleep and will not activate until you start driving (I don't remember the exact speed that they will wake up.) If it is when you are moving, it may indicate a sensor starting to go bad.
Paul
i think this is true only on the early C5's. mine just displays blank spots when parked until i drive it. my parents 2002 shows the real tire pressure every time its started.
as for the XXX, yeah its a relearn issue hopefully, if not , its time to replace the spensive little booger. some here have actually had success replacing the batteries, although they werent designed to do be replaceable.
