hey guys , got a ? .... I have a 99 FRC , buying 18x10.5 wheels for the back , will 305-35-18 fit on the rims and also will they fit the car ok???? rubbing???? can I still lower it ? Thanks!
That tire would fit fine on an 18x10.5 wheel, and would not cause any problems on the car.....no rubbing, nothing.. The Z06's come from the plant with 295/35x18's. BE sure the offset on the wheel is correct too, anywhere from +54 to +65
The hardest part for you will be to actually find a pair of 305/35x18's.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
