a/c not working.......
Old Feb 18, 2006 | 11:02 PM
123sugey's Avatar
123sugey
Dig
Default a/c not working.......
Live In Florida..... A/c Was Working Perfect. Temps Dropped To 50's So I Used The Heater For A Few Days. Then Temps Were In The High 70's Again. So, I Turn On The A/c And Now It Blows Regular Air- No A/c. Help Its Humid !!
Old Feb 19, 2006 | 07:26 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
wish we had your hot weather problem here
now for the A/C problem , do you hear th AC clutch engage ?( compressor run )
if not your freon might be low , and the pressure switch is staying open.
Old Feb 19, 2006 | 08:54 AM
jimcork1's Avatar
jimcork1
Default Be specific
You will need more information to get A/C help. Does the compressor click on when you turn on the a/c. Does the compressor cycle?
It is difficult to provide help without more specific information. There is always the option to take it in for service.
Have a nice day.. From way down in South Louisiana. Look at the avitar,, the boats in the background are gone.
99 Nassau Blue
Old Feb 19, 2006 | 03:03 PM
123sugey's Avatar
123sugey
Dig
i can hear the a/c compressor kick on. and cycling - i believe so.
and as far as bringing it to a shop......... this is south florida !!
last time i went to a shop for a/c problems (with anoyher vehicle ) they told me it was shot and i needed this and this and that for $1,600.00..
well, i ended up putting a fuse in and it worked for another 65,000 miles !!
Old Feb 19, 2006 | 11:06 PM
Der Flieger's Avatar
Der Flieger
Default AC Problems
Check your outside air temperature sensor. If it is not working properly, the air conditioner will not "know" it's hot enough outside to cause the controller to put a demand on the AC, even though it's engaging.
Old Feb 19, 2006 | 11:13 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
123sugey,
Do you have the electronic or manual A/C heater controls?
Are you able to feel the cold on one of the A/C pipes going into the firewall on the passenger side?
Has the battery ever leaked and possibly damaged the vacume lines/BCM below?
Can you hear the air mixture 'door' moving when you shift from hot to cold?
There have been reports of the mechanical actuating arm for the air mixture 'door' becoming dislodged -- do a search for it..
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Good advice.
Old Feb 20, 2006 | 08:49 PM
123sugey's Avatar
123sugey
Dig
air temp sensor is fine. i have electronic controls. the a/c pipe is very cold going into the firewall. the battery never leaked. but how loud is the air mixture door when closing / opening ? i cany seem to hear this.......
thanks for all the help.
Old Feb 21, 2006 | 11:32 AM
123sugey's Avatar
123sugey
Dig
Default actuator door ?!?
is the door easy to fix ?
Old Jan 2, 2010 | 07:13 PM
Sputnik1961's Avatar
Sputnik1961
4th Gear
I am having a similar problem. When ever I hit the AC button (I have the electronic system) the light on the button will flash about 4 or 5 times. The compressor clutch does not do anything.
I just had the compressor replaced recently so I went back thinking it was a faulty compressor. They said that the compressor is working so there is some problem between my HVAC and the compressor.
I am getting the code B0446 ( lest actuator out of range) I do not think that would make the compressor not turn on (plus I know this has been a problem for awhile but I do not usually have passengers so I do not care about that side of the car).
I have thought that the system might be out of freon but i figured the compressor would at least go through one cycle. I guess I could just popping in some more freon but would not want to overcharge the system if that is not it.
To a/c not working.......
