[Z06] Need help w/Vararam Install
Old Feb 19, 2006 | 05:05 PM
Paul4137's Avatar
Paul4137
Default Need help w/Vararam Install
I just got a new vararam. When you install the middle v piece so the rubber faces down it came with to little pieces of rubber that it says to put over screw heads. It seems like it will sit to high. Not sure what to do anyone delt with this? Does it matter which way the air filter faces? Mine is grey and both sides look the same. Thanks
Old Feb 19, 2006 | 05:36 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Mine is an older model but it went on as shown below. What filter did you get?
Old Feb 19, 2006 | 06:49 PM
Paul4137's Avatar
Paul4137
Its like a K&N , but it is grey its about an 1 1/2 thick.
Old Feb 20, 2006 | 02:38 AM
Z06-Goose's Avatar
Z06-Goose
Here's a couple of links that can help you...
http://www.cajundude.com/vararam.htm
http://www.zbramotors.com/vararam/VaraRam.html
...and since you're the mechanic incline, here's some good tips for other mods you may be doing yourself:
http://www.cajundude.com/c5techhome.htm
-Goose
To Need help w/Vararam Install
