Help reprogram wheel sensors
Old Feb 20, 2006 | 01:03 PM
fthefireman's Avatar
fthefireman
Default Help reprogram wheel sensors
Need help, lost the thread i had on how to reprogram wheel sensors on my 04. any help would be appreciated
pics of my rides. Thanks Frank
Old Feb 20, 2006 | 01:14 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Feb 20, 2006 | 01:15 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
This should help:
Just use a strong magnet in place of the J41760 Tire Pressure Monitor (TPM) System Programming Tool.
Old Feb 20, 2006 | 04:37 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Tech Tip
Resetting Tire Pressure Monitors -- 1 of 1
Date Published: 2001-07-02
Submitter's Name: Chris Palfi
Email Address: Private
Corvetteforum.com Member Alias: Brazen C5
I used this message forwarded from a fellow forum memeber and it worked just as described. Thought I would post for anyone else that may need to reset their TPMs. 1) Turn ignition on 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Feb 20, 2006 | 10:12 PM
fthefireman
Just wanted to say thanks for the help, Frank.
To Help reprogram wheel sensors
