[Z06] Front wheels skipping when fully locked
Old Feb 20, 2006 | 05:26 PM
Hammer's Avatar
Hammer
Default Front wheels skipping when fully locked
When I have my wheels at a full turn, I experience a skidding, jumping sensation, especially when backing out of my driveway.
Does anyone else experience this?
Jim
Old Feb 20, 2006 | 05:38 PM
Andy64's Avatar
Andy64
I think I have a similar sensation, but only notice that in the morning when its fairly cold out leaving my driveway as well. I never experience this at other time, so I just attribute that to the cold. Must be the morning Island due ... lol
Old Feb 20, 2006 | 05:47 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Very typical with the Z, especially in the cold as mentioned above, nothing to worry about.
Old Feb 20, 2006 | 06:19 PM
J Z06's Avatar
J Z06
Mine does it all the time. No biggy!
Jim, how many miles on it now? I am driving mine daily. It's a filthy mess...but luckily it'll be fully detailed around springtime.
Old Feb 21, 2006 | 12:58 AM
Hammer's Avatar
Hammer
Thanks guys.
Jay, I'm only driving in the dry weather. I think I have 5500 on it.
Jim.
Old Feb 21, 2006 | 02:03 AM
mkiv808's Avatar
mkiv808
Yep, mine does the same. Supra did it too. It's the cold.
Old Feb 21, 2006 | 07:51 AM
Hammer's Avatar
Hammer
mkiv808,
How do you like the C6 Z06 shifter?
Jim
Old Feb 21, 2006 | 07:52 AM
NeverT00Fast's Avatar
NeverT00Fast
Does anybody know why it does it? I always thought it was because the diff. is cold and the gears are binding?
Old Feb 21, 2006 | 09:11 AM
Thud's Avatar
Thud
Wide tires. When you have a wide contact patch, and the tire is going around a short radius, the inside and outside parts of the contact patch don't move at the same speed, so something has to "skip." The inner tire (i.e., the left front tire if your wheel is hard left) is most prone since it'll be turned the most.
When it first happened to me I thought it was a parking brake binding up, or possibly my steering rack about to fall out.
It might have something to do with the way the front tires are aligned, since my '90 vette also had wide front tires but never had this behavior.
Old Feb 21, 2006 | 09:23 AM
striper's Avatar
striper
It's the wide tires.
Old Feb 21, 2006 | 06:12 PM
J Z06's Avatar
J Z06
5500 eh? we're even!! I am close to 5600 actually!
It is too fun a car not to drive it daily. It's going to the car wash shortly to receive a high pressure spray(I REFUSE to drive it THROUGH a car wash, too high a chance of scratches) to remove the grime.
Old Feb 21, 2006 | 10:36 PM
ronman99vette's Avatar
ronman99vette
Cold tires stiff suspension
Old Feb 22, 2006 | 02:27 AM
whitezo6's Avatar
whitezo6
i had the same issue with my 96 Impala SS - i was told it was the wide tires and the sharp turning radius. it freaked me out everytime it happened, but i guess it's nothing but a thang
Old Feb 22, 2006 | 05:26 AM
mkiv808's Avatar
mkiv808
Originally Posted by Hammer
mkiv808,
Jim
Loooove it.
Old Feb 22, 2006 | 09:16 AM
DoubleZ06's Avatar
DoubleZ06
Mine does this every time I start up in the cold and turn out of the driveway or parking space. Seems to be no reason to worry!
Old Feb 22, 2006 | 09:27 AM
Purvis's Avatar
Purvis
You may also be experiencing "rearend chatter". This happens when the posi is cold, and there is not quite enough friction modifier in the rear. The posi then binds a little and you get a "hop" sensation.
Again, another normal Vette thing. You could try adding a little frction modifier to the rear end..
I had this same sensation that you describe, and this seemed to alleviate most of it.
To Front wheels skipping when fully locked
