? about how E brake works.
Old Feb 20, 2006 | 10:08 PM
Fourtrax250R's Avatar
Fourtrax250R
Default ? about how E brake works.
When the e brake is engaged on a C5, does it only lock the rear calipers? or fronts also? Thankyou!!
Old Feb 20, 2006 | 10:17 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Mechanical cable to the rears only. And only locks if you've adjusted the star wheel inside the drum. Mine when purchased couldn't have stopped a dinky toy.
Old Feb 20, 2006 | 10:28 PM
metnvette's Avatar
metnvette
6th Gear
Default Park Brake has Drum Brakes on inside of rotors.
On the inside of rotor (rear end side) there is a drum brake system for the parking brakes. It has a star wheel to adjust the drum.
Old Feb 20, 2006 | 10:32 PM
Fourtrax250R
ok, i understand now, thanx guys!
Old Feb 20, 2006 | 10:47 PM
troy144's Avatar
troy144
Old Feb 20, 2006 | 10:52 PM
rws.1's Avatar
rws.1
See some digital photos from the manual in my post in the tech section a few minutes ago
Old Feb 20, 2006 | 10:54 PM
Fourtrax250R
Old Feb 20, 2006 | 11:05 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Great. Thanks.
To ? about how E brake works.
