[Z06] Which Z06 should I buy
Hi Guys
I was going to by a 2000 Convertible but decided to go the Z06 route. My question to you guys is which year should I buy in the 2002 - 2004 models? Is there a difference? I know the 2001 has less HP and didn't come with HUD but does it matter in the 2002 -2004 models.
Dave P.
PS: If anyone has or knows of a nice low mileage Z06 for sale drop me a PM or E-mail at prine1@***.net or phone me @ 623 340-2379
Dave P.
04's had an improved fuel system which carried over to the C6.
Here's the full list, most are just differences between 01's and 02-04's
differences between 2001 & 2002 & up:
1. The LS6 engine standard in the Z06 increased from 385 to 405 horsepower. Torque increased from 385 to 400 lb-ft.
2. Front fender badges for Z06 models included the 405 HP designation.
3. LS6 exhaust back pressure was reduced by 16%
4. Cam shaft was redesigned resulting in increased lift and a 5% increase in air flow
5. Valve spring material composition was changed to increase seat load by 14%.
6. LS6 intake and exhaust valves were a new, lighter design.
7. The valve train weight was reduced by 0.81 pounds, which improved valve seating at high rpm.
8.Airflow over the LS6 MAF sensor was increased by removing grid work
9. MAF software was re calibrated
10. LS6 air cleaner housing had a larger intake
11. Wheels looked the same BUT they were cast spun instead of forged for a weight savings of 1.3 pounds per car
12. rear shock valving was changed
13. Improved clutch
14. Thicker front anti-sway bar
15. New front brake pads
16. HUD was standard (HUD was not avaliable in 2001 cars)
17. 2004 introduced a new fuel system which carries over into the new C6.
13. Improved clutch
Premium Supporting Vendor
The 04s also had upgraded shocks over the prior years, but these can easily be bought and installed on an 02-03.
I agree with the above recommendation to buy the newest one you can afford.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Originally Posted by bb609
Differences are small but the later models do have some improvements (more like corrections) over previous models. Buy the newest you can afford.
Thanks Guys
The tranny thing is interesting. I'll have to check into it. Now I just have to find the right car. I found a 04 in Vegas for $35K but was a day late. Should have jumped on it when I had the chance but was waiting to hear on the 2000 Convertible.
Thanks Guys
Dave P.
Thanks Guys
Dave P.
have an 01-love it..best bang for the $$-don't kid yourself,all yrs have good and bad ,based on previous owner , care taken ,and mods given,
whoppie-steel shift forks and hud.in 02-04's....if its $5k less and is in great condition..i would look at price and owner not necessarily the yr of the Z...at least get the color ya like..
look at allvette.net I bought mine from Lou I got an '02 with only 9000 miles it was and is perfect, I think he has a couple more, good guy to deal with. good luck! Ed
I am biased, but, for me it was an 04 CE Z06 or C6. Like others have said, they retuned the suspension(shocks), upgraded some tranny parts and fuel system. It was a car and driver 10 best. It was the last year of the C5 and the most refined. Even if it is little improvements, it's still improvements. Just my .02! That being said, you cannot go wrong with any Z06! Good luck.
Originally Posted by Subdriver
Many will debate how much of an improvement that was. The new fuel system which appeared mid-model year 2003 moved the fuel filter from the driver's side frame rail by the tranny to inside the tank, meaning to change the filter you need to drop the tank. GM will say the filter is good for life. I change mine every season.
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
Originally Posted by ZZOOM06
Another thing to consider is that the tranny was upgraded to steel shift forks during the '03 model year.
Originally Posted by tcal95z
I also think 01's are a great buy. Aren't the 01's about 45lbs lighter?
