Does that double sided tape really hold?
Old Feb 22, 2006 | 10:10 PM
Blowtorch's Avatar
Blowtorch
Default Does that double sided tape really hold?
OK, I got my screens today from Vetteshop. Nice quality and finish. But I'm looking at the attached double sided mounting tape and I'm wondering if this stuff is going to hold.
Should I just pull that stuff off and use some epoxy? Even duct tape looks like it would be a better choice.
Old Feb 22, 2006 | 10:12 PM
HERK's Avatar
HERK
velcro
Old Feb 22, 2006 | 10:15 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Not sure what came with your kit, but good 3M double sided automotive tape works great, but surface prep is paramount. Remove wax from paint and make sure it is clean, clean, clean.
Old Feb 22, 2006 | 10:41 PM
TPR492's Avatar
TPR492
St. Jude Donor '06
Prep w/ denatured alcohol found at any hardware store...
Old Feb 22, 2006 | 11:27 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I used the 3M to put on my Caravaggio spoiler and it works well. I used the denatured alcohol to take off the wax first.
Old Feb 22, 2006 | 11:42 PM
Cruisin''s Avatar
Cruisin'
I got the same screens and cleaning is very important. If you take some sand paper and scuff up, and then clean it real well (they send alcohol pads to clean the area with) where the double sided tape is going stick, I don't thing you will have any problems. Mine are on seem to be holding just fine.
Old Feb 22, 2006 | 11:45 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...If you ever try to get the screens off its murder unless you use velcro. Use velcro so the screens can be removed easily. I used velcro on my Z06 screens and to get them out I just slip a sheet of stiff plastic to seperate the velcro...otherwise it holds like its permanent
Old Feb 22, 2006 | 11:46 PM
BrianWe's Avatar
BrianWe
It will hold. Be very careful with the install on the rear screens. I lost both of mine in less than a week... All of the other ones have been good for about a year so far and over 20k miles.
Old Feb 22, 2006 | 11:48 PM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default Radio Shack
Radio shack sell pads that are very good that will hold just about anything. Pad is sticky on both sides.
Old Feb 22, 2006 | 11:57 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I got the same 3 pc set from Vetteshop. On the driver side cowl one side came loose and had trouble with both the back ones. I got some 3m industrial strength double sided tape and haven't had any problems since.
Old Feb 23, 2006 | 06:34 AM
wrustywrench's Avatar
wrustywrench
I cleaned that area very well and used a large bead of silicone adhesive , placed on the screen wherever it was to touch the body. I
placed the screen and spread the silicone out to smooth it over. I help the screen in place with a yard stick as a prop...
the silicone will allow removal.
worked real good and I know they will stay in place. The screen look cool...kinda exotic looking IMHO
Old Feb 23, 2006 | 07:11 AM
Some of the grey 3M double sided tape works very well.
Old Feb 23, 2006 | 07:47 AM
bowtiebubba's Avatar
bowtiebubba
Can you get the 3m double sided tape at any auto store?
Old Feb 23, 2006 | 07:50 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
The double sided tape will hold just fine..
Velcro is another good, and even better option in my opinion.
BUT, if you are talking about the Z06 front screens, they are NOT going to fall out with 2 sided tape. They are constantly being shoved into your car as you drive
Old Feb 23, 2006 | 08:11 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I see it at Pep Boys and Walmart.
Hold well.
Old Feb 23, 2006 | 09:51 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Where did you buy your 3m double sided tape?I asked in one store and they looked at me like i was a nut and said they only carry one type and it was not the industrial kind.Thanks charlene
Old Feb 23, 2006 | 10:03 AM
Wildcat99's Avatar
Wildcat99
I got mine at Ace hardware.
To Does that double sided tape really hold?
Old Feb 23, 2006 | 11:29 AM
99 vett babycar's Avatar
99 vett babycar
I put my screens on 3 years ago with double side tape and I'll have to use a crowbar to get them off.
Allow me to tell you where you can get the best double sided, water proof tape - Golfsmith ( or any other golf club component distributor ) sells double sided tape for REGRIPPING golf clubs. I use this stuff at least 2 times a week for jobs that come up around the house and it's never failed.( just don't buy the water soluable type ). When you apply it you can spray it with a solvent or some turpintine and it will remain moveable until the turp evaporates - allows you to get the right fitment.
Old Feb 24, 2006 | 06:17 PM
man00dude's Avatar
man00dude
St. Jude Donor '09
The tape doesn't hold when exceeding 130 mph....
Old Feb 24, 2006 | 06:51 PM
MY1STPEWTER
I think it was Lowe's.
