how much lube in diff
Old Feb 23, 2006 | 01:32 PM
STEEL's Avatar
STEEL
Default how much lube in diff
how many quarts does the differential need?
Old Feb 23, 2006 | 01:36 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Differential Lubricant
1.69 quarts
Friction Modifier
4.0 ounces
Old Feb 23, 2006 | 04:17 PM
birch64's Avatar
birch64
mine took ruffly 1.75qts of redline, didn't have to use the Friction Modifier. (thats what they told me)
Old Feb 23, 2006 | 05:23 PM
rws.1's Avatar
rws.1
Many who use aftermarket oil brands that claim you don't need friction modifier end up with chatter or whine that goes away when they subsequently add either GM addtive or an aftermarket posi additive...
I used 4oz of GM posi - additive( put it in first to ensure it is all there) then added Mobil 1 75W90 until full ( about 1.5 qts)
Old Feb 23, 2006 | 05:26 PM
JoshVette's Avatar
JoshVette
About 1.75. I'd put in the GM additive also.
You can always just fill it till it starts to come out the fill hole and then cap it off and you're good.
To how much lube in diff
