Opening convertible top
Old Feb 24, 2006 | 05:54 PM
mperl93's Avatar
mperl93
Default Opening convertible top
When I open my top the painted cover is very hard to close. It seems like the top is not folded down all the way. The latch is adjusted just find since when the top is up I can close the cover with little pressure. Any help would be appreciated.
thanks,
Mike
Old Feb 24, 2006 | 06:10 PM
tommybells's Avatar
tommybells
What year are we talking about here?
Old Feb 24, 2006 | 06:21 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
painted top??????
Old Feb 24, 2006 | 06:26 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
I don't know if this is the same problem. MPerl3 is kinda vague. When I go to put my top back up and I have it folded pointing up and try to close the cover, it hits when I try to put it down. Is there a way to adjsut this? I've tried with no luck. Either I am just a dumb@$$ or S.O.L. Which is? (boy did I leave my self open on that question.... )
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
thanks,
Mike
The owners manual says to give the center of the top a push once its down. My tonnough (how the hell do you spell tonnough) cover still takes a bit of a push to get it latched....Mines an 04
Old Feb 24, 2006 | 06:34 PM
rws.1's Avatar
rws.1
The rear deck cover on my '01 Vert also has some resistance on closing. Pushing down on the convertible top as Rocky L32 suggests helps a bit, but sometimes it takes me two attempts to get it to close properly.
Old Feb 24, 2006 | 06:51 PM
WvCorvette's Avatar
WvCorvette
My 02 takes a little force also...try pushing down in the middle and not on the sides when you shut it......My top hasn't been down in 4 months...
Old Feb 24, 2006 | 07:02 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Mine's the same way. I push it down in the middle and sides as much as I can before trying to close the tonneau (sp in have no idea ) cover. It's still a hit or miss situation. At least once it's down you know it's not going to be vibrating or making noises that would drive you nuts.
Old Feb 24, 2006 | 07:08 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I'm with the other guys. Give the top a little harder shove once it's down, then push the lid (Didn't have to write toneau-tonaeu-ton-oh the hell with it.) in the center.
Old Feb 24, 2006 | 07:51 PM
28tudor's Avatar
28tudor
Default It's the latch handles
after the top is down, turn the latch handles to where thet dont hit the reinforcing ribs on the cover, I believe (without going in the garage and looking) it's towards the outside. Makes a BIG difference......Makes me feel good that I have an answer! Enjoy the Convertible.
Old Feb 24, 2006 | 07:56 PM
tiojames's Avatar
tiojames
Default top
I have the same trouble on mine. I just push down hard right where the braces fold up on both sides and the waterfall closes fairly easy. If I don't do it is really hard to close the waterfall.
Old Feb 24, 2006 | 07:58 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
mine sometimes take two tries.
Only one try when I push in the center of the waterfall
To Opening convertible top
