[Z06] RedLine bad for transmission?
Old Feb 24, 2006 | 09:32 PM
skeet's Avatar
skeet
Default RedLine bad for transmission?
I heard that because of the base that RedLine uses in their ATF it causes the carbon blockers to swell. It was not a problem in the earlier C5's because paper blockers were used. I just bought the new Mobil 1 ATF Dextron V which is an improved Dex III and well replace the RedLIne MTL that is in there now.
Is anyone using Mobil 1 in their 6 speeds and how do you like it?
Old Feb 24, 2006 | 10:13 PM
gasboy's Avatar
gasboy
well,i've had redline d4 atf in my 02 since it was about one week old.no problems so far.
Old Feb 25, 2006 | 02:42 AM
atz06's Avatar
atz06
Has 11K miles with the Redline on my '03. Not a single problem. Much smoother shift that shock fluid. Hope this help.
Old Feb 25, 2006 | 08:25 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I use Royal Purple Max ATF synthetic automatic transmission fluid in my 2004 Z06.
Bob
Old Feb 25, 2006 | 12:16 PM
ErnieN85's Avatar
ErnieN85
almost 40,000 on mine with Redline D4ate. I talked with the Tremac engineers at Carlisle a couple of years ago before I change mine out. His take was that it would only make things better. BTW The paper blockers were in the early Trans, carbon in later models It's the paper that swells not the carbon
Old Feb 25, 2006 | 06:06 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I think you have that backwards...
The ester basestock in Redline fluids does cause swelling in most porous materials like the seals. But, I've read that was an issue with the older paper blocker rings, not the new ones. I ran Redline D4 ATF in my Z06 for a few years before shifting to AMSOIL ATF at the start of the 2004 season.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 25, 2006 | 08:01 PM
Sixxcat1's Avatar
Sixxcat1
I think your supposed to use Royal Purple Synchromax, not their ATF formula.
Old Feb 25, 2006 | 10:47 PM
C66 Racing's Avatar
C66 Racing
Well... I think that's open to debate. RP Synchromax is definitely favored by many, but it isn't labeled to meet the GM Dexron III standard for the C5/Z06 manual transmission. If a tranny under warranty fails, you may find yourself in a nasty fight with Chevy if they find out you are running a fluid not meeting owner's manual requirement. And I highly doubt RP will step up and cover the repair.
Old Mar 2, 2006 | 11:37 AM
GR8-LIFE's Avatar
GR8-LIFE
thats true of many manufacturers. They want you to buy their brand or a brand from another manufacturer that they have a business interest with. (Its a form of Sherman-anti trust if ya ask me.)
And you can say the same about oil. If I started using Penzoil synthetic and I tell my Dealer after my engine blows, GM will probbaly try to void the warranty because I did not use Mobil 1 even though the engine blowing probably would not have anything to do with the oil brand change
I remember when GM said no aftermarket radios or alrams too until they amended the Magnuson-Moss act.
In fact, Lou Bachrot Chevrolet would not fix a failed seat motor in my 1992 becaue i had an aftermarket radio
MAGNUSON-MOSS:
"a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson Moss Warranty Act (15 U.S.C. 2302(C))"
Old Mar 2, 2006 | 05:18 PM
C66 Racing's Avatar
C66 Racing
You are correct and not too many people know about the Magnuson-Moss Act.
If you look in your owner's manual, you will see that it doesn't require Mobil 1, probably because of this act. It requires an oil meeting GM Standard 4718M, which many 0w30, 5w30 and 10w30 synthetics on the market meet. GM wouldn't have a leg to stand on as long as you are using an oil meeting 4718M.
Similarly for the tranny fluid, the owners manual requires a Dexron III fluid which is why I think all the guys running RP Synchromax are leaning pretty far forward when it comes to warranty coverage on the tranny.
Old Mar 2, 2006 | 08:29 PM
crazyv6's Avatar
crazyv6
Subdriver, does the Amsoil Synthetic Manual Synchromesh Transmission Fluid (MTF) meet GM requirements? I was debating between Amsoil and RP for my 2004 Z16.
Old Mar 2, 2006 | 09:55 PM
C66 Racing's Avatar
C66 Racing
Like the RP Synchromax, the AMSOIL MTF does not meet the GM Standard (Dexron III) for the Z06. The AMSOIL MTF oil was designed to meet the older specs for the C4 manual transmission.
The only two AMSOIL transmission fluids which meet Dexron III standards are:
AMSOIL ATF (which is what I use)
AMSOIL Torque-Drive Synthetic Transmission Fluid
Old Mar 2, 2006 | 11:52 PM
vms4evr's Avatar
vms4evr
Royal Purple Synchromax does not meet the Dexron III standard. But their Max ATF does and also meets the Ford Mercon standard. So you can use that if you're under warranty and want to use RP.
Old Mar 3, 2006 | 07:39 AM
JiminVirginia's Avatar
JiminVirginia
A data point from the Supra owners' community:
Getrag, maker of the six speed box that went into the '94-'98 Toyota Supra, issued a bulletin telling Supra owners to use the standard Toyota fluid because in their experience, Red Line eventually caused internal tranny bushings to swell.
This is the transmission manufacturer talking, not Toyota pushing sales of its own fluid.
FWIW, I found out about this after making the switch to Red Line myself, and yes, the transmission felt great with the Red Line in it. But it dawned on me that renewing the fluid with the OEM Toyota fluid might also have improved shifting--since the old fluid was genuinely due for replacement.
I'd listen to Getrag. I'm not sure how all of this translates to the box in our ZO6s, but I'd err on the cautious side.
My $.02
Old Mar 3, 2006 | 07:43 AM
C66 Racing's Avatar
C66 Racing
Given the dates, I believe that is probably the same issue I discussed above related to the early C5 gearboxes. The newer C5/Z06 gearboxes apparently have a different blocking ring which the ester basestock of Redline doesn't swell.
To RedLine bad for transmission?
