Heater/AC Display
Old Feb 25, 2006 | 07:08 PM
01c5's Avatar
01c5
6th Gear
Default Heater/AC Display
My heater/Ac temperature digital display is not as bright as it used to be. I've checked the rheostat control and I can still make all the other dash lights bright/dim but the heater digital display is very dim. the other light controls for the heater are OK, it is only the digital temperature display. Thanks.
Old Feb 25, 2006 | 07:14 PM
rws.1's Avatar
rws.1
It is a common problem... associated with faulty solder connections on the power supply.
you can buy a new unit for about$400 + installation
or you can buy a used unit for about $150 with no guarantees or
you can PM Mandigital or e-mail him
David Ruberg digital1_guy@charter.net
David can repair most of them for about $50.... He give a 5 year guarantee on his work...
There are a number of write ups on how to remove the console and center of the dash ...
David fixed mine... it works better than new
Rich
Old Feb 25, 2006 | 07:22 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Try tapping it sharply with your knuckles. This has worked for some as a fix.
Old Feb 25, 2006 | 07:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Rich
I gotta go with Rich on this one. Wrapping it may fix it temporarily but it will come back. digital_guy will fix you up good as new.
Paul
Old Feb 25, 2006 | 09:55 PM
PaPaChoc's Avatar
PaPaChoc
The one on my 01 got like that, I could tap on it and it would come back on. It finally got to where I couldn’t see it so I went to my dealer (still under warranty) and he had to order the display. It took about 3 days to come in and the day they called and said to bring the car in it went back to working! I went ahead and had it replaced along with the emergency flasher as it was acting up. I got the old one from the dealer just in case it starts acting up, I’ll just send it off, get it repaired and replace it myself.
To Heater/AC Display
