wheel sensor problem
Old Feb 26, 2006 | 03:57 PM
motomafia's Avatar
motomafia
Default wheel sensor problem
guys just put new wheels on car, afterwords went through the tire sensor re-learn , all 4 wheels honked the horn when i re set them but displays No psi on the tires now.... after I did the last wheel the horn honked then i took the key out.... did i do something wrong? thanks
Old Feb 26, 2006 | 04:35 PM
wrustywrench's Avatar
wrustywrench
wont display pressure until you drive it....
if you have drove it,,,reset again and see if that helps...
