Electric Jack
Old Feb 27, 2006 | 11:27 AM
sage666's Avatar
sage666
Default Electric Jack
I've seen a lot of comments about wanting a jack for C5s. Just found this on the net and thought everyone else might like to see it. Claims it is only 4" tall and the stock C5 height is a bit over 5" so it should fit. I put frame rails on my 01 vert and use a motorcycle jack when I need to lift it.
http://www.autoaccessconnect.com/1ton12voelsc.html
Old Feb 27, 2006 | 11:36 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I bet that's a slow rascal.
Old Feb 27, 2006 | 12:01 PM
Woodstoc's Avatar
Woodstoc
I saw that at Walmart the other day when I was looking for a sissor jack. Didn't give it a second look, but perhaps I should.
I thought it might be too big to fit in the side compartments. My middle is taken up by an amp and 10" sub.
Old Feb 27, 2006 | 11:48 PM
Old Timer's Avatar
Old Timer
Default Electric jack
Got mine at Wal Mart (same jack). $39.95. Works great. NOT slow.
Barry
Old Feb 28, 2006 | 03:41 AM
SLPRC5's Avatar
SLPRC5
Barry
Now for the rest of the story.
I got mine there. Same price
I mentioned and showed this jack several months ago and got flamed for it. But it is one sturdy and fast jack. Has a claw foot base. Lifts the Corvette without any problems. Fits in the center storage compartment.
Old Feb 28, 2006 | 06:50 AM
Going to have to check it out at Wally's. I need a small jack for the car and this just might fit the bill. Thanks.
Old Feb 28, 2006 | 07:11 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Thanks for posting. Well worth a look see I think.
Old Feb 28, 2006 | 07:21 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
This is for me. Something that requires little or no physical labor to use.
Old Feb 28, 2006 | 08:07 AM
Oldvetter's Avatar
Oldvetter
BUT, will it fit under a C5 with a FLAT TIRE ? I measured to my front side jack point and got only 5.25 inches with a full pressure tire. My car is NOT lowered either. So I doubt this would fit under a C5 with a flat tire. You would probably have to put a piece of plywood under the claw base if you wanted to use it on soft (road shoulder) ground.
Looks like a good jack for maintenance use, but not for flat tire road use.
Old Mar 8, 2006 | 02:52 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I will be posting soon on the electric jack.....with pictures.......worked fine on my lowered car after a.....well........modification
Took me 40 seconds with my manual jack.............40 with this electric to raise the rear. less than 35 to lower...........vs 5 seconds with the manual.
11 lbs vs 21 with my other
Old Mar 8, 2006 | 03:01 PM
DPG's Avatar
DPG
St. Jude Donor '06
Looks like when you get a flat, you'll still have to try and drive onto a wooden block But hey beats carrying a heavy hydraulic jack in the car and faster than a manual siccors jack. Looks like i will be looking into this jack. I would only carry with 2 wooden blocks for trips outta town, one block to raise the car high enough to get the jack high enough and the other one a lot thinner one to support the claws from burying themselves on the side of the road.
Old Mar 8, 2006 | 03:11 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
looking forward to the reviews this is somthing that would work for me, thanks forn the pics to.
Old Mar 8, 2006 | 03:36 PM
mhdi22's Avatar
mhdi22
Old Mar 11, 2006 | 01:36 PM
sage666's Avatar
sage666
check out my air bag jack post...
To Electric Jack
