From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
What do you use.........
I have an '02 Coupe w/Black interior. The interior is starting to look a little "dull". What do you use to bring it back to life? Nothing that will make it real shiney. Just freshen it up. Thanks.
As suggested, you will find more of this info under the "General Corvette" section, "Car Care" section.
I use Meguiars NXT Generation Tech Protectorant for Vinyl/Rubber/Plastic on interior plastic.
I use Meguiars Gold Class Rich Leather Cleaner/Conditioner spray on the leather. I spray it on, level it, and let it sit overnight before wiping it off. It leaves leather soft and smooth.
I was turned on to this stuff a few years ago by forum members. Excellent stuff and has a wide range of applications. Gives that new look to the interior without that glossy shine.
Whatever you do, don't use the normal glossy Armour-all on the dash, the reflection is a real bummer!! Armour-all isn't the only product that has this problem either. Once you put it on, you're stuck with it until it wears off ...
I have used their Low Gloss stuff on the dash and it's not too bad.
