PIAA 1100x installed PICS
Old Feb 28, 2006 | 04:06 PM
obdoc_brother's Avatar
obdoc_brother
Default PIAA 1100x installed PICS
Ok everyone.. mod #2 is done. (#1 was the K&N intake)
I had a set of PIAA 1100x sitting around so I went ahead and took the leap. I was a bit scared since it seemed like the foglights were almost impossible to reach... and to my surprise.... it was EASY!! it took me a total of 1.5hr with clean up and doing it alone.
I thought I would share some photos for people out there needing help.
Pic 1: the headlight plastic bazel was removed to access the foglight. easy to reach with smaller hands.
Pic 2: here is a pic of the stock lights removed
Old Feb 28, 2006 | 04:07 PM
obdoc_brother
Pic 3 & 4: a pic of the stock fog light brackets on the PIAA's
Pic 5 & 6: shows where I ran the PIAA wiring and grounded it.
Old Feb 28, 2006 | 04:08 PM
obdoc_brother
Pic 7-11: INSTALLED! this is in the daylight in my garage. I can't wait till tonight and see them in action. I'll post more pics later.
Old Feb 28, 2006 | 04:28 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Feb 28, 2006 | 04:30 PM
02stlpewter's Avatar
02stlpewter
do you have a pic of where you ran attached the our wire coming from your PIAA?
Old Feb 28, 2006 | 04:40 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I'm planning to install mine this weekend. The pics are a big help - Thanks.
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats on the install! I've had mine for a couple years, they're awesome lights!
Old Feb 28, 2006 | 04:41 PM
obdoc_brother
I'm not to sure what you are asking for. How I connect the fog lights to the wiring harness? it is split like a "Y". one end of the Y is longer than the other one. so where I grounded the wire ,PIC 6, you can see the split there (right of the red circle). from there the short "Y" part went to the right fog light (passenger) and the longer "Y" part went in front of the car under the K&N filter.
PS> I did not wire this to the relay box. I ran the PIAA switch and 12V wire to the drivers side. I didn't want to splice anything into the relay box.
Hope this helps!
Old Feb 28, 2006 | 05:01 PM
HRDTOPC54FUN
Did you install the piaa relay?
Where did you tap in for + power. The instructions I have (corvettedreams.com) call for attaching it to the fuse box main power terminal, located at far passenger side of the fuse box.
Old Feb 28, 2006 | 05:17 PM
obdoc_brother
I didn't not tap into the relay box or cut the PIAA swtich off. I kinda like the PIAA swtich anyways, the PIAA relay switch hidden a bit but its to the right of the red circle in PIC 5. Its not picture but its right where the pic ends.
For inside the car and the PIAA switch, in is double faced taped right next to the hatch release and fog lights switch. and I had to run a 12V power source from the PIAA switch to the AUX fuse (I think its AUX) under the passenger carpet... its the same fuse I used for the amp. Pretty sure its ok, all the switch needs is a 12V signal which inturns the PIAA relay opens (or closes which ever it is).
For the main + power for the lights, yes this goes to the battery terminal.
Old Feb 28, 2006 | 05:40 PM
RPOZ4Z's Avatar
RPOZ4Z
why couldn't you use the existing factory fog light switch (and wiring) for the PIAA relay?
It would be a cleaner looking install and the wires are already there!
HRDTOPC54FUN
Thanks again.
Old Feb 28, 2006 | 07:36 PM
JETZ's Avatar
JETZ
Old Feb 28, 2006 | 07:58 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
thats the road I took.
Old Feb 28, 2006 | 08:32 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
Old Feb 28, 2006 | 09:14 PM
TigerSharkVette's Avatar
TigerSharkVette
i just got some last week and they installed them bad and their hanging down. but their nice at night
Old Feb 28, 2006 | 10:22 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
They sure do light up the night.
Old Mar 1, 2006 | 12:15 AM
obdoc_brother
Here are some night pics... the head lights are Silverstars.
Old Mar 1, 2006 | 12:18 AM
obdoc_brother
this one is with the Silverstars alone...
this is the PIAAs alone. check out the MPH sign.
and this one is the Silverstars and the PIAA's
they are difinitely HIDish...
To PIAA 1100x installed PICS
