Anyone have this problem while trying to lower their car
Old Mar 1, 2006 | 04:41 PM
Tenderfoot's Avatar
Tenderfoot
Default Anyone have this problem while trying to lower their car
I wanted to lower my vette (03 anniversary edition - F55 suspension). The front passenger side lowering bolt is frozen solid. Put 2 wrenches (for additional leverage) and WD40 on it but the thing will not budge. The guy trying this eats his wheaties, so a decent amount of muscle power was involved. We gave up. Driver side bolt loosens up OK. Any ideas?
Old Mar 1, 2006 | 04:45 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You have to "unload" the suspension - this is from Tech tips....
https://www.corvetteforum.com/techti...D=27&TopicID=1
Date Published: 2001-07-08
Submitter's Name: Doug Tronolone
Email Address: doug@e14k.com
Corvetteforum.com Member Alias: GoldMan
When lowering the front of a C5 (especially on older cars) many people are unable to turn the bolts. With the car jacked up & ready to lower (as in previous tips), place another small/standard jack under the end of the spring & jack it up enough to relieve some of the tension on the spring. This will allow the bolts to turn VERY easily with an open end wrench (or sometimes by hand). A small wood "block" between the jack & spring will protect the spring from possible damage. I also found it was not necessary to remove the front wheels.
Old Mar 1, 2006 | 05:01 PM
Tenderfoot's Avatar
Tenderfoot
The car was on a lift. A second jack was used to unload the spring but no luck
Old Mar 1, 2006 | 05:28 PM
Hammie's Avatar
Hammie
PB Blaster from your auto parts srote. Spray it on, let it set 30 mins- and hour, then repeat, then go out there later and try her out. The stuff works well. Your next best bet is heat, but I don't know much about lowering so I'm not sure what risks you run with any gaskets/bushings around there.
Old Mar 1, 2006 | 05:31 PM
chriscostas's Avatar
chriscostas
the bolt on my driver side was seized and i had done everything correctly. then after so much pressure the head of the bolt broke off, i had to turn the bolt with a vise grip from the bottom.
Old Mar 1, 2006 | 05:37 PM
ssmanofsteel's Avatar
ssmanofsteel
I feel your pain . Both of mine were frozen .I had to take the spring out and cut off the bolts .I left about 3/4" of the stud and used a rear bushing for my pad .With all this done the front lowered 1" . SRS
Old Mar 1, 2006 | 06:04 PM
Tenderfoot's Avatar
Tenderfoot
Didn't want to break anything off, so we stopped. Looks like my vette will remain unlowered for now
Old Mar 1, 2006 | 06:19 PM
tommybilt's Avatar
tommybilt
When you lower using this method how much does the car drop?
Old Mar 1, 2006 | 08:53 PM
corvette dave's Avatar
corvette dave
Get a pair of vice grips on the metal part of the bushing under the spring. Turn both directions. That usually works.
Make sure the rubber bushing is not stuck on the lower control arm. If it is, pry it apart.
Tommybilt,
Lowering on stock bolts usually lowers 3/4 to 1".
Old Mar 1, 2006 | 10:38 PM
Tenderfoot's Avatar
Tenderfoot
Tommybilt,
OK thanks. Will try that next time I have an opportunity.
Old Mar 2, 2006 | 06:20 AM
02gt350's Avatar
02gt350
so how much lowering is to much? ive heard guys say the bolts eventually broke because they took them to far
To Anyone have this problem while trying to lower their car
