Yet another tire size question
Old Mar 1, 2006 | 04:48 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default Yet another tire size question
Hi, I am thinking of running 255/40/r17, and 295/35/r18 on my wheels, I know these two tires are a little lower than the factory sizes which I have on now. Will this be really noticable difference in height, and maybe too low of a sidewall for a car that gets driven quite a bit, I do plan on lowering the car, (any advice on that would be good as well, such as what kind of problems am I going to run into by lowering it, and what is most likely to hit). Any advice is appreciated.
thanks,
--Chris
Old Mar 1, 2006 | 04:55 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Those sizes will work just fine. The diameter may deviate from stock C5 sizes about an inch...but they are OE Z06 size tires (well close- the Z uses a 265/40 front size..but the 255 will work just fine too).
I don't think you'll notice any problems or big differences with them. No problem with lowering the car either.
