[Z06] Drag Radials?
Old Mar 3, 2006 | 07:42 PM
JeremiahsC5's Avatar
JeremiahsC5
Default Drag Radials?
Just wanted some feedback before I purchase a set. I was thinking about running a set Mikey Thompson ET Street 275 40 17 on a set of front Z06 rims. Or is it better to run them on a 18 in rim. I know you gain width but you loose side wall. And you only have a few choices when you go to the 18in rims. Thanks in advance.
Old Mar 4, 2006 | 06:42 AM
Ranger's Avatar
Ranger
The MT ET Street Radial currently comes only in 275.40.17. The Z06 front wheels are a perfect choice. Great combo. Can yield the best 60' (mid-to-high 1.6) for a stock/near-stock Z06. Only downside is that because it's a very sticky tire, the launch rpm is high and that puts more wear on the clutch.
Second alternative is BFG DR in 315.35.17 or 315.30.18. Either will work with Z06 wheels. The former with fronts and the latter with rears. Those BFGs can produce consistent low 1.7X 60'.
Ranger
