Engine Noises
Old Mar 4, 2006 | 06:01 PM
PAST1SG's Avatar
PAST1SG
Default Engine Noises
I've Been Hearing A Noise Coming From The Lower End,i Think.
When I'm Starting In Cold Weather I'm Hearing Something Like A Rod Knocking,but It Goes Away After A Couple Minutes.has Anyone Had This Problem And Should I Get The Wallet Out ?
Old Mar 4, 2006 | 06:09 PM
CorvetteCrowley's Avatar
CorvetteCrowley
Im having the same problem with mine
Old Mar 4, 2006 | 07:14 PM
bops90's Avatar
bops90
Piston slap,go to search and read.Its ok, I have a 2000 that does it I have heard that puting on a better flowing oil filter will help!
Old Mar 5, 2006 | 10:28 AM
RR02Vette's Avatar
RR02Vette
Default too
Mine has been doing the same thing! Which oil filter would you recommend? When I changed my oil a few weeks ago, I think I used an STP with Mobil 1 full synthetic. Thanks
Old Mar 5, 2006 | 10:31 AM
iurutherford's Avatar
iurutherford
Does it sound a little like a sewing machine? I read somewhere on here our cars tend to have noisy valves but that its normal. Mine does basically the same thing when its cold.
Old Mar 5, 2006 | 10:36 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Not sure the year of your car, but that sounds pretty normal to me. My 1999 Z28 LS1 did it and my 2000 Coupe LS1 does it.
Old Mar 5, 2006 | 01:32 PM
SpeedUp's Avatar
SpeedUp
I have the same noises on my 02. I just put in a half can of Seafoam in the crank and the noise is gone.... Hope this doesnt cause other problems, but for now it seems to be helping
Old Mar 8, 2006 | 03:53 PM
CorvetteCrowley
tell me more about this seafoam..
Old Mar 8, 2006 | 06:02 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Seafoam is great stuff if used right. It's also a good fuel additive and an awesome air intake cleaner if you get the DeepCreep spray can of Seafoam (All Seafoam products contain the same exact fluid).
I am leary of using it in my oil though becuase it is a great lubricant for breaking rusty bolts andnuts loose. Also because of how well it cleans an intake. Not sure if I want too much in the oil or any at all because of it's solvent properties. changing the oil regualrly works for me.
For those of you that have boats, Seafoamworks great also because it was originally designed for marine applications that spend a lot of time in salt water.
Old Mar 8, 2006 | 06:22 PM
myblackC5's Avatar
myblackC5
Default filter
i have a 98 vette and it rattled when iit was cold. i changed to K&N oil filter, and it went away. same thing on my 99 chev 5.3. i was just getting ready to use the top end cleaner on my vette. i'll post the results...........
Old Mar 8, 2006 | 06:41 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Sounds like piston slap. Some have used different oil filters and some have even changed brands and wt of oil with some results.
Old Mar 8, 2006 | 07:07 PM
EB-Z06's Avatar
EB-Z06
Most all LS motors have that noise.
Old Mar 8, 2006 | 07:36 PM
DBRASUE's Avatar
DBRASUE
No fuel/oil additive/cleaner or different oil filter is going to make PISTON SLAP go away. If you used some or all of this stuff and your noise went away it wasn't piston slap.
Old Mar 8, 2006 | 07:45 PM
wrustywrench's Avatar
wrustywrench
Old Mar 8, 2006 | 07:50 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Here is my 2cents worth
We have been using amsoil in these LS1 motors and for what ever the reason it seems to be making then quiet, and yes it is piston slap.
Also are costumers are telling us that since using amsoil the fuel mileage has also increased.
Old Mar 8, 2006 | 08:08 PM
1965imp's Avatar
1965imp
IF it is piston slap it should go away when the crank starts splashing oil up on the cylinders., no oil filter will stop true piston slap.Once the engine temp. comes up and things start to expand and the oil starts flyin' around the crank case the noise should stop or subside.
Old Mar 9, 2006 | 01:44 AM
SLPRC5's Avatar
SLPRC5
So did mine..with Royal Purple 10W30 and a K&N HP1007 oil filter..my $.02
To Engine Noises
Old Mar 9, 2006 | 11:01 AM
jimcork1's Avatar
jimcork1
Noise what noise I can't hear a thing with the radio on. But I do hear the valve train click with the radio off, no piston slap or rod bearing/mains sound at all. But then mine is a 99
99 Nassau Blue
one final item I don't move the car on start up until full oil pressure is reached.
Old Mar 9, 2006 | 11:08 AM
SpeedUp's Avatar
SpeedUp
On average, how long does that take?
Old Mar 13, 2006 | 07:56 PM
PAST1SG's Avatar
PAST1SG
THANKS TO ALL WHO REPLIED,FEEL BETTER NOW! BY THE WAY I HAVE A 97 WITH 47K.
