Turn Off Key Wait 10sec?
Old Mar 5, 2006 | 06:50 PM
C5 YA 04's Avatar
C5 YA 04
Default Turn Off Key Wait 10sec?
Just got an oil changed . Went to back out of garage dispaly came on (turn off key wait 10sec) car died. Waited.. tried it started right up. I drove it home no probs. Why did this happen? Ive had the steering colum lock fixed like 3months ago. Is it about to happen again?
Old Mar 5, 2006 | 06:58 PM
jman1's Avatar
jman1
you need a CLB or the NEW recall done
Old Mar 5, 2006 | 08:22 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Sounds like a manual transmission C5..... Column lock is going to get you sooner or later.
That was the first sign....... See reply just above this one for the solution.....
Old Mar 5, 2006 | 08:23 PM
Bakersfield's Avatar
Bakersfield
That is what it is.
Old Mar 5, 2006 | 08:38 PM
C5 YA 04's Avatar
C5 YA 04
I just got it fixed 3months ago. Does it go out several times?
Old Mar 5, 2006 | 08:42 PM
chocoholic's Avatar
chocoholic
Clean the resistor pellet on your key, that's the most likely problem. You can also look up these messages in your owner's manual.
Old Mar 5, 2006 | 09:04 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Old Mar 5, 2006 | 09:05 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
CLB is the only sure way of correctiong this problem.
Old Mar 5, 2006 | 09:08 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
Is the NEW recall helping? I am ignoring the notices because of what has been said. I have the CLB but will need to wait till it comes out of storage to install.
Old Mar 6, 2006 | 01:05 AM
D_BlueVette's Avatar
D_BlueVette
could be a low battery votage.
Old Mar 6, 2006 | 01:26 AM
Skunkworks's Avatar
Skunkworks
You can defeat it with relay/wire harness. I had recall done and problem occurred after recall.
To Turn Off Key Wait 10sec?
