Climate control display
The climate control display on my 98 c5 is out. I understand there is a cold solder joint issue with these things and I would like to try and fix it! Can anyone send me a step by step on how to take apart the console so I can get the climate control unit out and take a look at it. All other functions work but I cannot see what mode I'm in nor any other info because the LED's are out. Thanks in advance.
http://www.vetteessentials.com/instr...t_install.html
I have only ever seen 1 post on what to solder... I will try and find it for you ... but no promises...
Rich
Repairs to lights on HVAC control panel
David Ruberg
123 W. Sarnia St.
Winona, MN 55987
507-429-4489
digitalguy_1@charter.net
Then - there is an Ebay guy that sells remanufactured units - I believe you return your bad unit as the "core".
http://cgi.ebay.com/ebaymotors/ws/eB...Pr4_PcY_BIN_IT
http://forums.corvetteforum.com/show...um_id=1&arch=1
they are the only two posts I have ever seen and the second really refers to the first
Rich
