Headlights still not working
Old Mar 7, 2006 | 01:30 PM
Jackflash's Avatar
Jackflash
Navigator
Default Headlights still not working
My pass side headlight on occasion wont open. I have discovered that if I rotate the manual **** toward the open position, even a half revolution and then actuate the light switch it will open fine. Its like the motor drives too far toward closed and binds up. Is there a stop adjustment,or an adjustment with-in the motor I can make? Iv already replaced the drive gears with Rodney Dickman units is there something I could have done wrong ? Sometimes if I just cycle the light switch the door will open but usually I have to rotate the manual ****.I would appreciate any suggestions anyone might have ,thanks
