The weather here on Long Island is supposed to be in the 60's this weekend so i've decided to change my oil for the first time. i'm all set but i have 1 questions - does anyone fill their oil filter with oil before installing? just wondering i know gravity will do that anyway once i fill the baby up.
The toatal amount of oil needed to change does not change. You are just adding saying a half of a quart to the oil filter, The remaining would be added to the oil pan.
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Just a friendly reminder... never trust a hydraulic jack alone- use a jack stand! Also, I hope you have better luck than I did when I did my first oil change. Just by coincidence I guess, my oil pressure sensor went after I did the oil change. So when I started up my car for the first time after the change- BING 130 lbs of oil pressure. I freaked out before I checked in here to find out it is VERY common for the sensor to fail. Good Luck- and enjoy!
so assuming i fill the oil filter - is it still a 6.5 oz oil fill or is now more like 6 oz?
It's still a 6.5 qt (not oz) fill, but that includes what you pour into the filter before installing it. In other words, you will use a total of 6.5 qts to do the oil change.
