Programing
Old Mar 8, 2006 | 01:48 PM
Vett Time's Avatar
Vett Time
Default Programing
I have new wheel sensors and the tool to reprogram .Where do I find the steps to do the job.
Old Mar 8, 2006 | 01:53 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I did a search for you, and this is from another Thread, from my memory, this seems to be correct.
Important: Make sure the vehicle has been stationary for at least 2 minutes before attempting to program the TPM sensors.
Turn the ignition to ON.
Press the RESET button in order to clear any IPC display warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the DIC RESET button for 3 seconds.
Notice: Refer to Body Control Module (BCM) Programming/RPO Configuration in Cautions and Notices.
Press the OPTIONS button again until the TIRE TRAINING message appears.
Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
Install the J 41760 J 41760 over the left front valve stem.
The horn will sound, indicating the left front TPM sensor is programmed.
When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
- LEARN R FRONT TIRE
- LEARN R REAR TIRE
- LEARN L REAR TIRE
Programming Cancellation
The programming mode will be cancelled if any of the following conditions are met:
- The program mode is exited through the DIC.
- The ignition is turned to OFF.
- All four sensors have been programmed.
- The TPM system has been in the program mode for longer than 2 minutes and no sensors have been learned.
If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
**** A strong magnet will work in place of the tool*******
Old Mar 8, 2006 | 02:01 PM
Vett Time's Avatar
Vett Time
Thanks man sound easy.
To Programing
