Getting a lowered vette on an alignment machine solved
Old Mar 9, 2006 | 07:20 AM
WKMCD's Avatar
WKMCD
Default Getting a lowered vette on an alignment machine solved
Yesterday I replaced my Kuhmo's with BFG KDW 2's and had the car aligned. I took the car to a specialty shop because I know they have the latest alignment equipment. The only problem was my car is lowered and will drag going up on the machine.
At first they said they couldn't get the car on their machine and couldn't do the alignment.
The solution was:
We had to pull the front up onto the machine until just short of dragging. Then we jacked up the rear of the car until it was level and pushed it onto the machine. Took it off the same way.
I really have to get those rail savers on.
Word!
Old Mar 9, 2006 | 07:29 AM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
I feel your pain, I'm dreading getting mine done.....
By the way nice choice on tires.
Old Mar 9, 2006 | 07:32 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
do you have any more bump steer?
Old Mar 9, 2006 | 08:25 AM
WKMCD's Avatar
WKMCD
Not that I've noticed. Lowering it did affect the alignment more than I thought it would. BTW, I run the z06 alignment. It definitely makes the car turn into corners better.
Old Mar 9, 2006 | 08:31 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
thats what im gonna get when i get mine done soon....
Old Mar 9, 2006 | 08:49 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
I know you're low, but couldn't they have just used ramps?
Old Mar 9, 2006 | 08:53 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
When I took mine, they just put some boards in front of the machine and drove up...no scraping.
jeff
Old Mar 9, 2006 | 09:02 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
too reasonable....
Old Mar 9, 2006 | 09:04 AM
jrose7004's Avatar
jrose7004
I found a shop here that has a pit!
Old Mar 9, 2006 | 09:10 AM
Max01GreenMachine's Avatar
Max01GreenMachine
2017 C6 of the Year Finalist
Cruise-In VI Veteran
jeff
I'm SLAMMED in the front. I have lifetime alignment at Firestone and I take full advantage whenever I change shocks, wheels, tires, or suspension height. They have it down, no problem. I drive it up to the ramp, they put some 2" x 8"s in front of my wheels and on it goes. Comes down just as smoothly. 335 Pilot Sports are here and going in as soon as I toast the rest of the Nitto DRs
Later,
Max
Old Mar 9, 2006 | 09:21 AM
DPG's Avatar
DPG
St. Jude Donor '06
The solution was:
Word!
this is how I got my car on a 4 post lift at my old high school. Im lucky and my old autos teacher lets me use his shop
Old Mar 9, 2006 | 09:29 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
The solution was:
Word!
That's the only way Grond would get on the machine. Even so, my headers still got hung up on the center jacks (required some more jacking on the sides)
Old Mar 9, 2006 | 06:32 PM
1-BAD-VETTE's Avatar
1-BAD-VETTE
I just went to a place with a pit alignment! Simple. But $100.
Old Mar 9, 2006 | 06:36 PM
stillborne's Avatar
stillborne
Later,
Max
Slpain how you get dis!!!
Old Mar 9, 2006 | 06:42 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Word...
Peace
Willfulone
__________________
..................Click for
Old Mar 9, 2006 | 10:07 PM
JETZ's Avatar
JETZ
I'm dreading it too, local Porsche dealer has a new Hunter 400, getting on will be interesting!
Old Mar 9, 2006 | 11:41 PM
MY1STPEWTER's Avatar
MY1STPEWTER
jeff
To Getting a lowered vette on an alignment machine solved
Old Mar 10, 2006 | 12:21 AM
JETZ's Avatar
JETZ
My other concern is the fixtures placed on the wheels. I've had wheels damaged by having these fixtures over tightened by the mechanic, and they've left four marks. The Porsche dealer has a 'special fixture' that hooks over the tire itself at two points, no contact with the wheel.
Old Mar 10, 2006 | 06:27 AM
WKMCD's Avatar
WKMCD
That's the exact machine my used. The car hangs on the running boards even with 2x10 boards strategically placed. Make sure you are there when they put in on and off.
Old Mar 10, 2006 | 06:43 AM
Dark-Knight's Avatar
Dark-Knight
I found Ruff auto here in Dallas is the only place I can get my ride on the rack!
