Window Motor CABLE - please help
Old Mar 9, 2006 | 03:43 PM
pvknight's Avatar
pvknight
Default Window Motor CABLE - please help
Driver side window started making noise while going down, felt like there was some play in the regulator.
Read up on the forums, removed the door panel, and checked everything out. Found that the cable is stretched and not taught on the pulleys like it should be. Is there any adjustment for the cable? Or any way to replace the cable and not the entire ($280) regulator?
Til then, hopefully it won't bind!
Please advise. Thanks.
Brian
Old Mar 13, 2006 | 12:20 PM
pvknight's Avatar
pvknight
any help? Window gets more problematic each day.
Old Mar 13, 2006 | 12:29 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Had that same problem on another GM car, not the vette. Cable finally binded. Only solution was to replace entire regulator. Sorry for the news but you might try to find a cheaper replacement. $280 seems awfully high to me.
Old Mar 13, 2006 | 12:45 PM
Ron C!'s Avatar
Ron C!
I just replaced my driver's side. I got mine from SMC Performance on ebay. $140 shipped.
Old Mar 13, 2006 | 12:50 PM
pvknight's Avatar
pvknight
Did you replace it yourself? I'm trying to find a write-up on this.
Brian
Old Mar 13, 2006 | 03:31 PM
Ron C!'s Avatar
Ron C!
No, had it done by someone who has done it a bunch. Took him around 15-20 minutes. Would have taken me much, much longer.
Old Mar 14, 2006 | 02:27 PM
pvknight's Avatar
pvknight
Thanks everyone. A definite DYI-er
http://forums.corvetteforum.com/show...post1554422247
Brian
To Window Motor CABLE - please help
