Bose???
Old Mar 9, 2006 | 11:26 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Bose???
Why does the back speakers sound so weak compared to the front...I mean I can hardly hear them when I fade back to the rear speakers only....is this normal...
Tony
Old Mar 9, 2006 | 11:29 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Yes, they are midrange speakers that do little to help the stock Blose system.
Old Mar 9, 2006 | 11:31 PM
JEEP/C5's Avatar
JEEP/C5
I believe its do to them not being amplified. The front speakers have small amps in the doors. I was thinking of replacing rear speaks with small amp but it’s not simple due to being a Boise system. Don’t remember all of the particulars but you need some sort of module to make it compatible with the ohms from the stock Boise head unit or you have to replace the whole system with after market system.
Old Mar 9, 2006 | 11:34 PM
MedChoice Tony
Default Thanks
Sounds like I'll just live w/ it...don't want to replace everything..
Old Mar 9, 2006 | 11:56 PM
fej's Avatar
fej
To quote scott .. Check the faq
But to help ya, the front 8" "subs" are individually amplified in the blose system. The deck runs the front 3.5" "twiddlers" mounted above the subs in the door as well as the rear speakers (5.25" for verts/frc's and 6.5" for coupes) from the factory. There is no true tweeter in the blose system. Easy upgrades are adaptor + sub and amplifier to add some real bass, generally coupled with a replacement of the front twiddlers with an Infinity mid/tweet coaxial speaker to improve the highs in the stock blose system.
Check out audio/electronics in general corvette. Lots of us around often to help
Fej
Old Mar 10, 2006 | 06:29 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Fej
Actually, the rears in the coupes are the "oversized" 6.5s, or as some manufacturers call them, 6.75"
To Bose???
