[Z06] I'm getting PI**ED....
Old Mar 10, 2006 | 07:51 PM
vettethret's Avatar
vettethret
Default I'm getting PI**ED....
Well, I just picked my car up after 1.5 months of waiting to get my wheels re-chromed (long story, chromer was backlogged). So I get in the monster happier than a fat kid eating his birthday cake, and 5 miles down the road I smell anti freeze and look down and the reduced engine mode was in full effect. The main hose coming from the radiator was completely collapsed. Had to have the car flatbedded to WCC. As you can see it's not easy to load on a flatbed. Has anyone ever had this happen? I'm trying to figure out if my electric waterpump went out or it was just a bad luck deal. All I know is I'm sick of this thing breaking and not being able to drive it. But I still love it. After driving my lifted f-150 for 1.5 months, it felt like a formula race car.
Old Mar 10, 2006 | 08:01 PM
TEXHAWK0's Avatar
TEXHAWK0
My guess is that your water pump is working fine, but cannot draw enough coolant into it because your radiator cap is not allowing the coolant to be drawn from the overflow tank.
Did you try loosening the cap to see if the hose returns to normal?
Old Mar 10, 2006 | 09:42 PM
vettethret's Avatar
vettethret
I didn't try that. I dont know how many times the car was started in 1.5 months, so maybe it was becuase it sat so long?
Old Mar 10, 2006 | 10:04 PM
xilr8n's Avatar
xilr8n
1.5 months is nothing to us in snow country.
Old Mar 11, 2006 | 12:43 AM
Amar1995's Avatar
Amar1995
Your hose didn't collapse because of the radiator cap. Generally, when they collapse it is because there is not enough coolant/liquid in the system. You have a leak in the coolant system somewhere. Look deeper, trust me. The suction effect is from air expantion/contraction.
Good Luck,
Nick
Old Mar 11, 2006 | 01:59 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Sorry to hear it Mike, hang in there!
Charlie
Old Mar 11, 2006 | 07:28 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Good Luck,
Nick
I've seen this happen. Fill it up completely and monitor the situation.
Bob
Old Mar 11, 2006 | 07:45 AM
spdislife's Avatar
spdislife
Hate to say it but that's not the root of your problem.
Old Mar 11, 2006 | 05:14 PM
RoHo's Avatar
RoHo
Hey, let us guy's on the forum know how you made out on this deal and what the fix was
Old Mar 11, 2006 | 09:45 PM
Monnie's Avatar
Monnie
Good Luck,
Nick
Agreed! I thought about this and re-read his post again.. he said he smelled the coolant, so...
Old Mar 15, 2006 | 12:24 AM
Amar1995's Avatar
Amar1995
Any updates ???
Old Mar 15, 2006 | 12:42 AM
vettethret's Avatar
vettethret
Any updates ???
Stopped by the shop today to drop some parts off. John, who is the head mechanic, says they ran the car for 10 minutes and it stayed at 185 degrees. He thinks the thermoststat could have gotten stuck or it's a head gasket. He was going to drive it home to see if it did it again. At this point, if it is a head gasket, I'm going to part the car out. This many problems on a car with 25k is enough. It's either a new Z or an srt-10. I still love my car so I hope it's only the thermoststat. I guess the new thing is to ditch the thermostat alll together and use washers to let the flow in. He says he's done it for a couple cars. Hopefully will know by the end of the week.
Old Mar 15, 2006 | 01:53 AM
TheDVS1's Avatar
TheDVS1
Don't ditch the 'stat! You'll just be trading one problem for others. BTW, if you're smelling antifreeze, it's likely not the thermostat. As others have said, you probably have a leak and you're creating air pockets, which is very hard on your radiator!
If your system has a leak, your expansion tank will continually be getting drawn down to the add level (after you've added more fluid) or beyond after the car has been run and sits overnight. If there are no leaks, the coolant level will stabilize and so will the amount in your expansion tank. If your head gasket is going, your oil should have the tell-tale "chocolate milk" look to it, and a simple compression check should confirm if that's the problem. This shouldn't be that difficult to diagnose.
Good luck and hang in there!
Old Mar 15, 2006 | 10:40 AM
stano's Avatar
stano
"Hang in there" as Charlie says Mike and I'm sure you'll get it figured out.
I've often thought about going back to stock too, but I'm glad I didn't ( so far )
Old Mar 15, 2006 | 11:52 AM
vettethret's Avatar
vettethret
Death before rolling stock stano. It just sucks having a big *** car payment on a car you only drive 6 months out of the year, in Southern CA to boot. I don't know how the guys in the east do it!
Old Mar 15, 2006 | 01:38 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Living in SoCal I'd have an SRT-10 with some loud pipes and a 19/20 HRE setup with a thumping stereo.
That or a Ferrari F-355 Spyder.
Old Mar 15, 2006 | 02:14 PM
IH8PONYS's Avatar
IH8PONYS
Had that same problem in my 99' Hardtop, it was the thermostat. Just changed the stat/housing and flushed the radiator, worked great!
Old Mar 15, 2006 | 10:33 PM
vettethret's Avatar
vettethret
Thats the exact viper set up I'm thinking of.
To I'm getting PI**ED....
