Jacking point or tie down point?
Old Mar 10, 2006 | 08:10 PM
jmzvet's Avatar
jmzvet
Default Jacking point or tie down point?
There has been some debate as to whether the 4 "jacking points" on the frame rails are actually intended as a jacking point or manufactured there as a tie down point for transport. Maybe both uses are intended?I use the front and rear cross members as a jacking point.
Does anyone have reliable information?
Old Mar 10, 2006 | 08:17 PM
HummelS's Avatar
HummelS
They can be used for both, imho - if you need to jack from the side, they are the only place where bare metal is exposed, and also provide you with a handy place to hang a jacking puck.
Also if you are lifting using the typical 4-arm lift, the arms should be placed under the bare metal with a jacking puck installed at each point.
Jim!
Old Mar 10, 2006 | 08:24 PM
cenzo's Avatar
cenzo
My Flatbed guy has a Y-harness with hooks that insert into the framerail slots. Yanks er right up there with out a problem. So i think they serve both purposes.
Old Mar 10, 2006 | 08:26 PM
shannanl's Avatar
shannanl
I have a book titled "Corvette C5 Performance Projects 1997-2005". It talks about jacking locations.
"The C5 came from the factory without any visible jacking points. According to the shop manual, the proper points to lift the car with a four-point hoist are the holes that were used to attach the chains on the transporter. These holes are located on the frame rails of the car and in the approxmately the same locations as the jacking points of the C4. But the body of the C5 wraps down the side of the car and rolls under the frame rails. The body actually covers a great deal of the frame rails. There are small cutouts in the plasitc rocker panels for access to these openings, but they help only a little. Most floor jacks (also four point lifts and jack stands) have pads larger than these openings, meaning that the lifting pad too often rests on part of the body, not the steel frame..."
It also goes on to say "It's almost as if GM designed these front and rear crossmenbers as jacking points. While GM recommends other points, it didn't take Corvette owners long to figure out that the corssmembers work really well.
TEXHAWK0's Avatar
TEXHAWK0
If you are looking for a source, the GM Chassis Service Manual used by dealers shows these points to be lifting points. Also, the company that makes the special tools for GM dealerships (Kent-Moore) sells a version of the jacking pucks with a chain attached to remind the mechanic to remove them before driving. The Kent-Moore part number is J-43625.
Old Mar 10, 2006 | 08:38 PM
jmzvet's Avatar
jmzvet
Good point! A buddy of mine forgot to remove his jacking puck. He drove over a speed-bump, the puck caught, and dented his frame rail pretty good. He's still pizzed about it even though it can't be seen unless you look under the car .
Old Mar 10, 2006 | 11:17 PM
Dave1998's Avatar
Dave1998
If you go to www.awdirect.com and search for T-hook, you will see these nice hooks that go directly into the slots for tie downs.
$6.99 each
Old Mar 11, 2006 | 12:38 PM
Len16's Avatar
Len16
From the 2000 Shop Manual ...
Old Mar 11, 2006 | 01:03 PM
sage666's Avatar
sage666
Can also install alumininum frame rails and not worry about it.
Old Mar 11, 2006 | 01:21 PM
Stefan99's Avatar
Stefan99
All Jacking points:
Old Mar 15, 2006 | 03:53 AM
Reevo's Avatar
Reevo
You might want to check this thread,,,,,
http://forums.corvetteforum.com/show...S&forum_id=103
I just made these wood lifts yesterday,,,if you follow the instructions carefully they work great.
To Jacking point or tie down point?
