Tire Sensors - Can't Program - (Evil) Please Help
Old Mar 11, 2006 | 12:45 AM
morepower's Avatar
morepower
Default Tire Sensors - Can't Program - (Evil) Please Help
This is long post but please stick with it:
I am having problems programming my tire pressure sensors. I have read the shop manual and many postings and still can’t figure out why I can’t get them to program.
I have an 04 Coupe. I replaced the stock wheels and TPSs with new polished aluminum wheels with new small TPSs preinstalled. I understand these are the standard type for the 04 model.
My key FOB works perfectly.
I have also tried many different magnets from 2” long rare earth magnets to the magnet from a 15” subwoofer. I hold the magnet next to the valve stem, usually on either side of it. The magnet is held parallel with the valve stem.
I have tried at least 20 times to program the sensors. Out of the 20 times I got the left front to beep the horn twice. When I move to the right front wheel, I get nothing.
However, if I initiate the programming sequence and hold the magnet near the sensor for the left rear tire, it always beeps the horn. But then I move to another wheel and get nothing again.
I also tried placing one of the stock wheels near the car and got it to respond once to the programming sequence.
Is this how the sensors work ???
The magnet closes a switch in the sensor causing it to transmit a signal that is picked up by the FOB receiver. Each sensor transmits a unique ID code (with pressure data) so the computer matches the sensor’s signal to the appropriate location (LF, RF, LR, RR).
Troubleshooting:
1) If the above is true then I should be able to place the stock wheels with sensors near the car and program the system using the magnet. But this doesn’t work either. OK, I suspect the magnet is not strong enough.
2) I understand that the FOB receiver is located overtop the left rear wheel well which is the only wheel that consistently responds to the magnet. OK, I suspect the receiver has a range problem (although the FOB works fine).
3) Tomorrow, I will move the LF wheel to the LR position and see if it responds. If it does then its not the magnet or sensor. If this works I guess I could place each wheel on the LR as I go through the programming sequence and if each transmits a unique ID the computer wouldn’t know the differences.
Anyone else experience this much difficulty and how did you resolve the problem? THANKS…
