tailpipe alignment
Old Mar 11, 2006 | 03:49 PM
chevyvette1's Avatar
chevyvette1
Default tailpipe alignment
just need to know what I need to do to get both sides of the tailpipes to hang the same,one side is a little lower than the other, thanks Ozzie
Old Mar 11, 2006 | 04:13 PM
binkysgarage's Avatar
binkysgarage
I had the same problem, when I did my clutch the 2 bolt flanges in front of the rear suspension can be loosened up and moved helped out alot. You might have to enlarge the holes a little bit. Some times the mufflers move in the inlet side, may have to reposition and tack weld to keep from moving.
Old Mar 11, 2006 | 05:42 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just by bending the muffler brackets will also move the pipes up and down
To tailpipe alignment
