Sway Bars
Old Mar 12, 2006 | 01:48 AM
soggysailor's Avatar
soggysailor
Default Sway Bars
Anyone have a link for a good deal on Z06 sway bars. I've seen a couple for around 250.00 But now that I want to buy I can't remember who that was??Thanx.......
Old Mar 12, 2006 | 01:55 AM
scott_fx's Avatar
scott_fx
just got mine from fred beans look into some c6 z06 shocks while you're at it... great price and great customer service
Old Mar 12, 2006 | 04:24 AM
Pizzano's Avatar
Pizzano
http://www.corvetteforum.net/c5/kenf...rtspage1.shtml
Just got mine here the price shown on this page was actually $235.00,not $283.00, when I ordered, and thats with the endlinks.
And boy you will love the feel of them on the road.
[[[And when its time to install this installation tip works great]]]
Originally Posted by Pizzano
I just got done installing them on my vehicle also,piece of cake ,the tip to do the rear while on the ground worked great(or in my case I jacked up the vehicle and then put the vehicle back down on the planks I use to raise the vehicle this way I dont need any floor jacks to raise the vehicle up, the planks I use are about 6 inches high.
I did the whole vehicle without removing any tires,worked out smooth , took me about 1.5 hours total between raising the car and doing the work.
If I may suggest this technique(as stated by another forum member Mike ).Damn!!and I was going to take pics of each step and post them on my website, but I forgot.
[FOR THE REAR]
Raise the vehicle, or do it on the ground(too low for this cripple to do it that way),so Like I mentioned before how I raise my vette for work, with the tires down on my supports, I removed the rear sway, and removed the endlink nut that goes into the lower wheel support, so when you remove the old swaybar, the endlinks will be attached to the bar still.
[[[May I also add, when removing the original endlinks, I found it easier to just hold the nut with the 18mm open ended wrench, and back out the torx with the ratchet, this way your not fighting for space to menuever the open end wrench a notch or two at a time.]]]]
Remove the old endlinks, Keep the factory nuts/bolts you will need them again for the install(new hardware is not supplied with the new parts,in case you didnt know), then install the new endlinks onto the new sway and torque to 53 ft lbs while the new sway bar is still out of the vehicle, this way all you have to do is hook up the lower endlink nuts and your all set.Align the bushings up correctly (the old and new sway bar had markings on the bar for where the bushings attach to),Bolt up the bushing clamps (upper bolt is 49ft lbs, lower nut is 70ft lbs), and torque the other ends of the endlinks to 53 ft lbs.
Thats it your done, none of the suspension moved , so you dont have to worry about mis alignment of anything.
[THE FRONT]
I raised the vehicle the same exact way, with the tires resting on the planks as if it was on the ground again, like the way the rear was done.
Left the endlinks attached to the old sway and only unbolted the lower link nuts,so the sway removed has the old endlinks still attached to it, as with the rear, I removed the old links, and installed and torqued the new links to the new bar before installing it,again 53ft lbs, then I installed the sway, aligned up the new bushings (the bushing goes in only one way ,there is a grove that fits into the topside of the bushing) torqued the bushing clamp bolts to 43 ft lbs, then attached the remaing link nuts and torqued to 53 ft lbs.
There ya go , Mission accomplished, Hope this helps somone out there that is going to do this upgrade.
This tip was given to me from another forum member.
Old Mar 12, 2006 | 05:30 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
just ordered and installed the above...haven't got to drive it yet
Old Mar 12, 2006 | 07:48 AM
mcintex's Avatar
mcintex
St. Jude Donor '06-'07
Fred Beans gets my vote. Installed bilsteins and Z06 sways with heim links. Got a alignment and cornerweighting and it made a heck of a difference.
Old Mar 12, 2006 | 07:52 AM
Check with Fred Beans or Fichtner Chevy. About the best prices you will find unless you buy used.
Old Mar 12, 2006 | 10:55 AM
Gene@FredBeans's Avatar
Gene@FredBeans
Hi there,
Thanks for the plugs guys. We have the best prices shipped on the bars. You can buy them 2 ways from us, with or without the end links. For final pricing shipped and all go to www.fredbeansparts.com and click where it says click here to search by part number.
For the kit with the links use part number c5z06bars under Chevrolet make.
For the kit without the end links use part number c5z06barsNL under Chevrolet make. NL stands for no links.
Thanks,
Gene
Old Mar 12, 2006 | 12:02 PM
Pizzano's Avatar
Pizzano
Originally Posted by Gene@FredBeans
Hi there,
Thanks,
Gene
Does Fred Beans not charge for shipping?
Old Mar 12, 2006 | 12:26 PM
Ken Fichtner's Avatar
Ken Fichtner
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
We are confident that we have the lowest prices + NO SALES TAX + NO EXHORBIDANT SHIPPING AND HANDLING + IN STOCK SAME DAY SHIPPING
Give our parts department a call toll free at 800-234-5284 for the latest specials and to place your order.
Check out this post from another forum member as well:
http://forums.corvetteforum.com/show...72&forum_id=71
Thanks for the mentions in this post!
Ken Fichtner, Dealer
Fichtner Chevrolet
Old Mar 12, 2006 | 12:54 PM
Pizzano's Avatar
Pizzano
Fichtner Chevrolet
No Problemo, Im always game for giving credit where credit is due, $256 shipped to my door in 2 days,no hassles,and as specified on the phone to me, DO NOT LUBRICATE the bushings,per GM/Fichtners.
Old Mar 13, 2006 | 08:04 PM
Gene@FredBeans
Bottom line fellas... nobody beats Beans... nobody..
We are your Corvette headquarters. We have more Corvette parts in stock at times than GM has stock of them!!
We are the first to have the parts and we keep the prices the best in the country!
Thanks,
Gene
Old Mar 13, 2006 | 08:45 PM
MrLeadFoot's Avatar
MrLeadFoot
I have a front Z06 bar that's coming off the car in a few days. Brand-new, but been on the car since Friday, but too firm for me. Replacing with Z51 front bar. Might save you a couple of bucks, and you only need to buy the rear one. New bushings and all.
Old Mar 13, 2006 | 11:20 PM
JEEP/C5's Avatar
JEEP/C5
I have the z06 rear bar (used) PM if interested. Also have z51 front bar.
To Sway Bars
