key fob loosing memory help?
Old Mar 13, 2006 | 12:23 PM
cujo200231's Avatar
cujo200231
Default key fob loosing memory help?
i just baught my 99 vette and the fob didnt work when i got it. so i baught a battery, pressed the lock and unlock until it worked and it would work for a few minutes when the passive switch was off and didnt work at all when the passive switch was on. am i not re-syncing it right or is my key fob defective? also there is a slight rattle in the actual computer board, i took it apart and there is somehtin rattleing in there. but it seems that if that would cause it to not work it wouldnt workl at all. any suggestions?
Old Mar 13, 2006 | 02:17 PM
byte_me's Avatar
byte_me
I have a similar issue with one for my 97...I thought it was the battery but when I changed the battery and re-synched it with the car it works the first time, but then it does not (not even the passive) so I am too curious as to what to do...my other one works fine and I have two programmed into the car using the DIC.
The rattle you hear is the passive feature...there is a little switch in them that causes it to trigger by movement. That is normal.
Old Mar 14, 2006 | 06:41 PM
cujo200231's Avatar
cujo200231
thanks, at least i know that its not broken, hopefully now i can get it workin somehow
Old Mar 14, 2006 | 06:57 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
a lot of posts and threads have addressed this issue .
if the battery replacement did not cure the problem , then unfortunately it's time to replace the FOB ,like I did , and buy new if you can , a bit pricey for the 97 - 99 , but that will fix your problem .
Old Mar 14, 2006 | 11:22 PM
cujo200231's Avatar
cujo200231
then the passive switch will work fine? how often to these things die?
Old Mar 16, 2006 | 03:59 PM
sts57c5's Avatar
sts57c5
ditto i agree replaced battery on both of mine did not work now i need to buy a new one for 2000 vette if I can find somewhere to buy one.
Old Mar 16, 2006 | 04:59 PM
red97vette's Avatar
red97vette
mine died too, ...arg... ive been too lazy to fork up for $$$ for a new one for the 97. Ive been using my key like a ho-bo...
dan
To key fob loosing memory help?
