closing the hood
Old Mar 13, 2006 | 04:34 PM
Fire's Avatar
Fire
7th Gear
Default closing the hood
could somebody tell me how to adjust your hood so you don't have to slam it by shuting it? thanks
Old Mar 13, 2006 | 04:47 PM
4-speed's Avatar
4-speed
I just gently close the hood then press the rear corner until it cliks then walk around to the other side and press down on that corner untill it clicks. I close the hatch the same way, I dont like to slam anything.
Old Mar 13, 2006 | 04:49 PM
rhoge's Avatar
rhoge
Ditto
Old Mar 13, 2006 | 04:51 PM
JChrisF's Avatar
JChrisF
Old Mar 13, 2006 | 04:55 PM
shakainc's Avatar
shakainc
I agree. But found that pressing over the top of the latch works better. It's not all the way at the corner.
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I just drop mine from about 6 inches up and it closes. It helps if you lubricate the latches.
Old Mar 13, 2006 | 05:01 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
and if that doesn't do it.>
Old Mar 13, 2006 | 05:03 PM
DAS ZED's Avatar
DAS ZED
Old Mar 13, 2006 | 05:06 PM
tiojames's Avatar
tiojames
Default closing hood
I used to drop mine from about 6". When I put the carbon fiber hood on it doesn't weigh enough to close itself so I do one side at a time by pushing down over the latch area.
Old Mar 13, 2006 | 05:15 PM
This is what I do too. Takes a little longer, but it ensures the hood latches securely.
Old Mar 13, 2006 | 08:04 PM
JUSAKD's Avatar
JUSAKD
I slam it. I'm in a hurry to drive it.
Old Mar 13, 2006 | 08:55 PM
Roadking's Avatar
Roadking
I have a carbon fiber hood and I stand in front of the car using two hands gently push and lower shut.
Old Mar 13, 2006 | 09:02 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I press each side over the latch. Same with the rear hatch.
Old Mar 13, 2006 | 09:06 PM
TEXHAWK0's Avatar
TEXHAWK0
If the rubber bumpers at the rear of the hood are adjusted right, you can drop the hood from 10 to 12 inches and both sides should latch.
I used to shut one side at a time, but decided there was less stress on the hood to just drop it and let both sides latch at the same time.
When I got my car from the factory, if I dropped it, one side would latch but the other side wouldn't.. I adjusted the bumper down a little on the tight side, and now both sides latch perfectly every time.
Old Mar 13, 2006 | 10:38 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Carbon fiber hood here too... I slam it from about 12".
Old Mar 13, 2006 | 10:46 PM
spdislife's Avatar
spdislife
mine from 4", or there abouts
Old Mar 13, 2006 | 10:50 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
If you have an oem hood...
...a finese drop from 4-6 inches will do...(latches lubed and the height adjusted properly...)
else...lower gently and press firmly over latch on each side of the hood...
...aftermarket hoods with a low tolerance...I recommend the latter...
...then slam the gears...
To closing the hood
Old Mar 13, 2006 | 10:53 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
adjust the little rubber bumpers at the corners. I think it is a 12mm wrench. loosen the nut and turn the rubber bumper. I did mine a turn at a time until it worked perfect. Can drop it from 6 inches and it shuts perfect. took a little while to get it just right so the bumpers wernt too far down.
Old Mar 13, 2006 | 11:59 PM
edensknight's Avatar
edensknight
Old Mar 14, 2006 | 12:04 AM
wpdjoey's Avatar
wpdjoey
