Trickle Charging Battery-Optima
Old Mar 13, 2006 | 07:17 PM
HeyVern's Avatar
HeyVern
From: Grace Valley: A small, peaceful & beautiful valley in the Volunteer State
Default Trickle Charging Battery-Optima
Any downside to using a trickle charge on a regular basis? Sometimes I go 3 or 4 days without driving my C5--home office, bad weather and/or need for a kid seat in the other vehicle. I routinely put my hood up after driving and have a quick connect/disconnect for my WalMart charger attached to my Optima Red Top. Can you overdo it?
Old Mar 13, 2006 | 07:59 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Hey Vern at Wallmart you can get a float charger for about 20.00 it will cycle on and off and keep your battery at full charge. I have been using mine and it keeps the voltage in the 12.23 area.
Old Mar 13, 2006 | 08:06 PM
bsmithC5/2004's Avatar
bsmithC5/2004
I have a battery tender , Leave it plugged in all winter This is the second year and no prblems . I leave the hood closed which is another question asked
Old Mar 13, 2006 | 08:11 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
If you drive the car every 3-5 days you shouldnt need to do anything. This forum is full of people that park thier cars for months over the winter months and dont have any problems.
If your battery charger doesnt cycle on and off (prbably doesnt if its a moderatly priced 2 amp charger) I wouldnt use it.
Are you having battery problems, is something draining it?
Your red -top shouldnt need anything but a drive now and then
Old Mar 13, 2006 | 08:36 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Go with the battery tender if you must charge when not driving. The Optimas are designed to hold up really well if you don't have anything draining them. Like said in a previous post, driving every 3-5 days shouldn't hurt. Mine sat for almsot a month during the Christmas/New Year timeframe and started right up.
I let one sit in my 88 GTA for almost 8 months while in boot camp and OCS. Guess what..it started the car right up with no problems.
Old Mar 14, 2006 | 12:20 AM
Atascadero_Kid's Avatar
Atascadero_Kid
two things will kill a battery quicker than anything... one is repeated deep discharging... the other is overcharging.
If your battery is not getting weak in between drives, leave it alone. You are likely to do more harm by trying to "top off" the charge than the slight discharge the battery will undergo with a few days or even weeks of non-use.
AGM battteries are even more sensitive than regular ones to overcharging. The plates are so tight that the heat overcharging creates will damage them in short order. This is one reason you should NEVER use a high output charger on an AGM battery.
Old Mar 14, 2006 | 07:13 AM
I've had a Battery Tender hooked up to mine during the past two winter seasons - not one problem.
To Trickle Charging Battery-Optima
