Do we all live w/ it?????
Old Mar 14, 2006 | 01:07 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Do we all live w/ it?????
Or is it just me? The grinding "marbles in a can" sound around 1K rpms. It goes away after 1k rpms and sometimes you cant hear it depending on how fast you take your speed up. Also, can someone explain why it does this
Thanks,
Tony
Old Mar 14, 2006 | 01:09 PM
WKMCD's Avatar
WKMCD
Not me, but I don't ever remember driving my car at 1k
Old Mar 14, 2006 | 01:11 PM
tiojames's Avatar
tiojames
Default grinding
Have seen a couple of posts about it, but have never heard it in mine.
Old Mar 14, 2006 | 01:33 PM
REDEVIL's Avatar
REDEVIL
It drives me nuts. I hate rattles/noises/or anything like that.
I believe it's the throwout bearing making the noise and has something to do with the transmission being mounted in the rear. Do a search on "drivetrain noise" and you'll find everything you ever want to know about this issue. I find it very strange that GM would put a design into production with that sort of business going on.
Old Mar 14, 2006 | 01:59 PM
DPG's Avatar
DPG
St. Jude Donor '06
ive heard here that it is often times the stock h-pipe. many have replaced this with a xpipe and the problem has gone away. If you still have a warranty, see if gm will fix it, or just get an xpipe.
Old Mar 14, 2006 | 02:05 PM
HERK's Avatar
HERK
check the two small springs that attach to the exhaust.
Old Mar 14, 2006 | 03:05 PM
Al '92's Avatar
Al '92
It's only in the six spd cars and I believe they mention it in the manual and on the video. It's transmission noise. Mine does it too.
Old Mar 14, 2006 | 03:45 PM
jrose7004's Avatar
jrose7004
I have an A4 so no I don't have that sound!
Old Mar 14, 2006 | 03:56 PM
jman1's Avatar
jman1
most 6 speeds do it.....i just take off quicker
Old Mar 14, 2006 | 04:02 PM
Tom/99's Avatar
Tom/99
Old Mar 14, 2006 | 04:34 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
I got rid of it by putting on some B&B Bullets, now I cannot even hear a train sneaking up on me.
Old Mar 14, 2006 | 05:00 PM
D_BlueVette's Avatar
D_BlueVette
Old Mar 14, 2006 | 05:03 PM
CorvetteCrowley's Avatar
CorvetteCrowley
Originally Posted by D_BlueVette
same noise here 6speed 01
Old Mar 14, 2006 | 05:06 PM
chargedsol's Avatar
chargedsol
borla stingers and a CD take care of that..
Old Mar 14, 2006 | 05:11 PM
vetterlatethannever's Avatar
vetterlatethannever
I very rarely notice mine but I did drive a friends Z06 the other day and it was very noticeable.
Old Mar 14, 2006 | 05:25 PM
It is just a noise inherent in the 6-speed tranny. All of them do it to some extent - I just raise the rpms a little bit and then take off. Seems to cure the marble sound.
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
It's the tranny on the MN6 cars (T56) my C5, and my 99Z28 do it. It's the output shaft spinning with no, or very little load on it... it does it also if you shut your car off in Neutral with the clutch out...
just take off faster, or give it some more gas so your RPM's are not so low and you will not hear it
also, if you shut your car off in Neutral, hold the clutch down and you won't hear the sound.
To Do we all live w/ it?????
Old Mar 14, 2006 | 07:06 PM
MedChoice Tony
Default Wow
Thanks for all the info...guess I'll speed her up more often....
Old Mar 14, 2006 | 08:55 PM
vetterlatethannever
That's when I hear it
Old Mar 14, 2006 | 09:12 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
some B&B Bullets make all the creaking, popping, squeeking, squeeling and anything else you can think of (passenger bitching, etc) go away!! Or else, it hides it very well anyway!!
Glen
