need to remove center console HELP
Old Mar 15, 2006 | 04:11 PM
kvanek's Avatar
kvanek
Default need to remove center console HELP
I have removed the 2 screws that are in the cig lighter area.
I dont see any other screws to take out. How do i get this thing off?
Reason for removal is i need to change the solenoid that locks
the A4 in the park. I hope it is under there once i get it off.....
Old Mar 15, 2006 | 04:15 PM
HummelS's Avatar
HummelS
Pop off the little grill by the ignition - there's one in there. Be careful not to damage the temperature sensor.
Old Mar 15, 2006 | 04:16 PM
TOOGECKO's Avatar
TOOGECKO
There is one other screw located behind the temp sensor cover next to the ignition switch. Gently pry it off and you will see a third screw. You may also have to remove the console itself- it is held in by four 10mm nuts, two under the traction control plate and two at the back of the console under the door. Vette Essentials has a detailed removal process on their website. Just another one of Ken King's contribution to us
Old Mar 15, 2006 | 04:18 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Default help
two bolts under the panel that has your ride control and such ( AH also). Also it's much easier if you remove the center glove box also. Hope this helps
Old Mar 15, 2006 | 04:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
One of the many things the late Ken King brought to our community are instructions on how to do whatever it takes in the interior of the C5. His instructions will be his legacy.
http://www.vetteessentials.com/instr...t_install.html
Here's to you, Ken!
Old Mar 15, 2006 | 04:25 PM
MYRagtop's Avatar
MYRagtop
Here's to you, Ken!
Ya beat me to it. I've used these same instructions more than once.
Old Mar 15, 2006 | 05:16 PM
kvanek's Avatar
kvanek
Directions Are Great However I Cant Get The Thing Out Of Park To Lift The Bezel Off.
Old Mar 15, 2006 | 05:22 PM
TOOGECKO's Avatar
TOOGECKO
Have you removed the shift selector **** and boot? This should give you a little more clearance to lift it over the shift lever...
Old Mar 15, 2006 | 05:46 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Put the E-brake on.... turn the key to acc., step on the brake pedal and shift into 2nd
Old Mar 15, 2006 | 05:47 PM
MyVetteDream
Here's to you, Ken!
Old Mar 15, 2006 | 05:50 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Old Mar 15, 2006 | 06:57 PM
kvanek's Avatar
kvanek
Ok I got it out of park and have the bezel off.
Little disapointed not seing a solenoid type mechanism in plain veiw.
If i start removing the bolts around the shifter am i looking for trouble??
To need to remove center console HELP
