Max tires for Wagon Wheels
Old Mar 16, 2006 | 06:03 AM
l80ous's Avatar
l80ous
Default Max tires for Wagon Wheels
Whats the best size for the wagons on the rear, running 275's and they just dont look wide enough, though i dont want to ruin the handling, is there much tire roll if I change?
Old Mar 16, 2006 | 07:20 AM
Oldvetter's Avatar
Oldvetter
Be aware if you have OEM Goodyear runflats that they are about 2 inches wider than other size 275's. This is why they "look" so good on a C5. Also runflats handle better than nonrunflats, Corvette Enthusist just tested them. Now they don't "hook up" or ride as good as nonrunflats. Runflats also get like 10% better mileage.
Even though you go up sizes in other tires, you may not get a wider tire.
Old Mar 16, 2006 | 11:59 AM
shurite44's Avatar
shurite44
Two inches wider, are you sure. That would make C5 runflats wider than Z06 tires. Actually that would put them in the neighborhood of a 325-335 series tire. Have you ever seen how far a 335 series tire sticks out past the fender on a non tubbed C5.
Runflats handle better than non runflats, . I think thread starter better wait for a few more opinions on this one. The gas mileage thing also fails to pass the smell test, especially 10%.
If Corvette Enthusiast published that sort of misinformation I am happy I do not read it.
Old Mar 16, 2006 | 12:30 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
i didn't notice much tire roll difference. I ran 295's on my waggon's in the rear no problem.
Chris
Old Mar 16, 2006 | 03:47 PM
Oldvetter's Avatar
Oldvetter
-I just went to tire rack and the rear stock EMT tire is 10.3 inches in tread width. The rear Z06 tire (295) is only 10.2 inches ! So you are in fact correct !
-Other widths: Firestone = 8.6 inches; even Goodyears 275 F1 GS D3 (rated highest in recent tests) is only 9.4 inches wide.
-I noted this once before, it seems like Goodyear and GM created a special size runflat that is wider than other similiar size tires.
-I did not make up the other facts either.
Old Mar 16, 2006 | 06:26 PM
shurite44's Avatar
shurite44
I did not say it was made up, I just said it was wrong. I don't question peoples integrity on the forum.
I have seen both tires and I still don't agree with the numbers that the runflats are 2 inches wider than other 275 series tires.
Add 2 inches to an average 275 series tire and you are looking at over 12 inches, in other words a 325-335 series tire.
Old Mar 17, 2006 | 12:06 AM
99TorchTop's Avatar
99TorchTop
Default Fronts??
What about fronts on the wagon wheels? 275 possible???
Old Mar 17, 2006 | 12:25 AM
shurite44's Avatar
shurite44
I have heard of members running 17" inch 275 series tires on the 8.5 in rim and putting them on the rears. So they will fit but not ideal.
Personally I would not go any bigger than Z06 size tires on the wagon wheels, in other words 265's on the front and 295's on the rear.
To Max tires for Wagon Wheels
