Installed Column lock bypass found this?! PIC
Old Mar 16, 2006 | 07:12 AM
tommybilt's Avatar
tommybilt
Default Installed Column lock bypass found this?! PIC
Installed the CLS last night and found this under the steering column. Did not have time to chase the wires is this a normal corvette switch or is it an aftermarket switch for almost anything?
Old Mar 16, 2006 | 07:15 AM
hardtop's Avatar
hardtop
looks like an aftermarket alarm bypass switch. used for valet parking.
Old Mar 16, 2006 | 07:16 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
It is NOT normal. Looks like it could be an ignition cut off switch. Who really knows????
Old Mar 16, 2006 | 07:17 AM
SEAMOORE's Avatar
SEAMOORE
Is it a 6 speed? Maybe a switch to prevent it from starting that interlocks w/ the clutch. Flip it and see if the car will start. If not, that's it. Cheap and effictive, but will not stop a rollback.
Old Mar 16, 2006 | 07:18 AM
wt2ga's Avatar
wt2ga
Kill Switch ?
Old Mar 16, 2006 | 07:19 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
What? You found a blurry picture of a toggle switch?
Sorry, couldn't resist!!
Old Mar 16, 2006 | 07:26 AM
tommybilt's Avatar
tommybilt
I hear that about the rollback, when I park somewhere sketch I try and turn my wheels all the way one way to give them a hard time.
Old Mar 16, 2006 | 07:34 AM
cenzo's Avatar
cenzo
It's the Passenger Ejection Switch (PES).
If you have a coupe, it will blow of the Targa and propel the passenger out da car!
In convertibles, the offender goes through the fabric as lowering the top at speed can be hazardous.
This option was not availble in FRCs or Z06s
I wish I had one
Old Mar 16, 2006 | 07:37 AM
, probably a kill switch that was installed to help protect the car. No a bad piece of extra protection.
To Installed Column lock bypass found this?! PIC
