Removing A4 shifter HELP
Old Mar 16, 2006 | 12:03 PM
kvanek's Avatar
kvanek
Default Removing A4 shifter HELP
I need to remove the shifter to replace a solenoid that is bad.
I have all the plastic off and now want to remove the shifter.
I see several nuts around the outside of the shifter assembly.
If i remove these nuts and pull the shifter out am i going to have problems.
I just need a little direction before i tear into it...Thanks
Old Mar 16, 2006 | 01:25 PM
kvanek's Avatar
kvanek
Somebody surely know this
Old Mar 16, 2006 | 02:05 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I don't think you have to mess with those 4 bolts, but I could be wrong. You need to take off the shifter **** and then the boot in order to get to the A/T shift lock control solenoid. Is that the solenoid you're trying to replace?
jeff
Old Mar 16, 2006 | 02:39 PM
kvanek's Avatar
kvanek
jeff
Yes thats the solenoid. It is not working properly and my car gets stuck in park.
I will tear into it and see what happens.
Old Mar 16, 2006 | 02:59 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
On the front of the shifter there is a big Staple. If you take small flathead a pry it out. Pull the **** up and it will come off
This will help
http://www.vetteessentials.com/instr...t_install.html
To Removing A4 shifter HELP
